Timing chain - single vs double
Old 04-07-2016, 03:13 AM
BURL
BURL's Avatar
Default Timing chain - single vs double
Going to be doing a F/I install on a 58,000 mile C5. Will be Paxton 1500, max 10 PSI, stock bottom end, 6,200 RPM limit. Using 317 heads with Tooley .660 lift Platinum springs. Baby cam with intake - low 220's Exhaust - high 220's.
You F/I guys that have been through some engines - do I need to go to a double roller timing chain or will a good single be OK? Which ever way you lean, what is a good quality budget set brand?
Thanks in advance.
Old 04-07-2016, 05:46 AM
Steve@C56
Steve@C56's Avatar
So, quite new engine...
Low boost...
Stock rpm limit...
Overkill spring (this baby cam never will touch the 660 lift)...
A brand new LS2 will be perfect
My 2 cents
Personnaly have more miles, more boost (18psi), more CI (LS1 stoker), all forged, more cam (640 lift range), more rpm (have hit le limiter and seen +7400rpm for last +200feet on 1/4m drag strip because ****ing 4th gear dont pass), and i'm fine with LS2 chain
I know i push the limit on some parts (LS1 block, T56, rear and axle....), but i'm not stressed about the chain
See other FI guys before choose
Old 04-07-2016, 10:00 AM
BURL
BURL's Avatar
Thanks for the reply. Good analysis. Good info.
Low boost...
Stock rpm limit...
My 2 cents
Old 04-07-2016, 10:15 AM
5 Liter Eater
5 Liter Eater's Avatar
St. Jude Donor '11
After having a Comp double roller start to come apart on me I'll never stray away from stock gears and CxR chain. Not worth the hassle.
https://www.corvetteforum.com/forums...y-oil-pan.html
Old 04-07-2016, 01:26 PM
corvettebob1
corvettebob1's Avatar
Don't remember the brand but I used a double roller when I did my H/C on my car several years back, it also gave the option to advance or retard the cam.
I will also say I've replaced many factory T/C sets that failed but never found a failed D/R. I would suspect Bill's problem came from a failed damper.JMHO
Old 04-07-2016, 05:28 PM
BLOWNBLUEZ06@RKT Performance
Supporting Vendor
BLOWNBLUEZ06@RKT Performance's Avatar
I don't care for double rollers, regardless of the manufacturer. I've seen the LS2 chain fail more than once. F/I regular, PeetyZ actually called me from the side of the road once to help diagnose his issue remotely and it was his LS2 chain with less than 20kmi on it. I actually started a big write-up on timing chains. I'm going to be offering a chain not seen before that is designed to withstand far more than any of the chains currently on the market. I'll start the sale as soon as I have time to manage it.
The picture of the three chains: Top one is a C5R, middle one is C7R and the bottom is mine.
Tumble polished billet steel gears, black oxide coated.
OP, let me know if you're interested in one.
__________________
Offering products from A&A Superchargers, East Coast Superchargers, Mechman Alternators, Mantic clutches, RPS clutches, Kooks Headers, Lakewood, LG, Brian Tooley Racing, Comp Cams, FAST, ARP, UPP Turbo systems, Wiseco, Callies, K1, MAST Motorsports, Haltech and many more. PM me for details.
Old 04-07-2016, 05:41 PM
CamminC5
Support Corvetteforum!
CamminC5's Avatar
St. Jude Donor '15-'16-'17-'18
Gimme one Bret. I got the car apart now.
Old 04-07-2016, 06:04 PM
Shoaf85
Shoaf85's Avatar
I'd be interested if available within the next month or so. My new setup will be together by then hopefully.
Old 04-07-2016, 09:06 PM
CamminC5
CamminC5's Avatar
NEW setup. You mean you want to go faster?!?!?
Old 04-07-2016, 09:34 PM
Supporting Vendor
They're available now.
Old 04-07-2016, 10:06 PM
MVP'S ZO6
ISIS SUCKS FAT CHOAD
MVP'S ZO6's Avatar
I have seen and installed this chain Blownbluez06@RKTPerformance has. It's certainly much more robust than anything out there that I have seen for these engines.
Old 04-07-2016, 11:38 PM
5 Liter Eater
St. Jude Donor '11
Get one to Houston by Saturday?
Old 04-08-2016, 05:25 AM
Rkreigh
Rkreigh's Avatar
looks really good! very interested PM or post details on cost
very nice work and timing (pun intended) couldn't be better
Old 04-08-2016, 04:17 PM
PEETYZ
PEETYZ's Avatar
You had to bring that up huh ? lol
Needless to say I went C5R this time around
Old 04-08-2016, 04:45 PM
Supporting Vendor
I'll text you.
Old 04-08-2016, 10:08 PM
inspector12
inspector12's Avatar
Nice Brett I remember us talking about it, didn't know you were going this extreme on the chain. Look very beefy! I like it.
Old 04-11-2016, 03:42 PM
BURL
BURL's Avatar
Default Chain failure
What chain was this that failed?
To Timing chain - single vs double
Old 04-11-2016, 04:04 PM
PEETYZ
PEETYZ's Avatar
BURL,
This was the LS2/LS3/LS7 chain
Old 04-12-2016, 01:00 AM
stryderss
stryderss's Avatar
I am currently running brets chain on my beast with the new timing gears. the lower sprocket has little dots in it for advancing and retarding your cam. It is very robust and is actually pretty tight compared to other single chains on the market. very impressed !!!!
Old 04-12-2016, 08:39 AM
SBCGENII
SBCGENII's Avatar
That chain looks beast Brett. What dampener you are runing plays a roll in timing chain life.
Here is a podcast with the owner of ATI and he talks about dampeners in it. Good info. For one I didn't realize the dampener for truck motors or vettes was internal different and setup for different rpm.
http://mixlr.com/power-and-speed-pod...ance-products/
Quick Reply: Timing chain - single vs double
