PROBABLY THE BIGGEST IMPROVEMENT WE'VE MADE TO SUPERCHARGER SYSTEMS in years
Received 1,194 Likes
St. Jude Donor '15
I'll buy one if it will fit (C6). I'd have to look at it closer to see if there's any chance of it working
I really like the bearings though. Mine is really creaky feeling when I try to move it, presumably from the lack of bearings in the factory units
Platinum Supporting Vendor
I wonder if they would sell me a bracket?
St. Jude Donor '15
Haha, you might have to use an alias for that purchase!
Former Vendor
It will also work on our Procharger brackets. I haven't figured out belt sizes for 10 rib yet but I should be able to get that done next week.
You could modify the bracket at home with a drill, 3/8 - 16 tap and a saw of some type. The bottom of the bracket just needs to be trimmed enough to allow the arm to swing through it's arc. The one problem is that there is an existing hole that intersects the point where we need to put a new one. That hole needs to be welded up and milled smooth before the new hole can be drilled and tapped.
We can modify the bracket and install the new tensioner for about $400. (including the tensioner of course)
I am supposed to get 25 completed tensioners today so we should be good to go by next week.
Running Guns & Moonshine
When will those radiator hold downs be shipping out? I'll be ordering a set.
As for the pulley - it's on my list after I get the system tuned and dialed in.
Looks like a quality upgrade. I'm in the process of changing from an 8 to a 10 rib and this is coming out at the perfect time.
Email sent to Josh, waiting on availability.
#34
St. Jude Donor '15
Call the shop
#35
I don't think so. I would need to make some sort of a mounting plate.
Just Call the shop. We have a bunch now.
We started shipping kits with the new tensioners today! Five went out today and it looks like six for tomorrow.
#37
Here's one... Do you guys still produce brackets for prochargers? If so, what would one cost with the new quick change pulley piece?
#38
Yes. 10 rib with 8" balancer is done. (see above)
Yes. We still make the procharger bracket. I think it will be right at $800 for the complete setup.
#40
Right now we are modifying the the existing bracket to accept the new tensioner. I'm having a complete new bracket made so I don't have to spend the time doing this for very long.
I don't have a price on the new front plate yet. I'll probably sell the tensioner and front plate as a unit. It will bolt to your existing rear plate, spacers etc.
Yes. 10 rib is available.
We are shipping complete kits with the new tensioner but not tensioners by themselves just yet.
