Dyno # guesses?
Old 01-11-2016, 06:40 PM
416yellowz
416yellowz's Avatar
Default Dyno # guesses?
Having my car dynod this week.
Curious to see what yall think she'll put down!
-98 c5/ 6spd / 93 pump gas/ dynojet
-forged ls1
-vortech v3 ti trim w/ 3.6 pulley
-Arun's jamcam. 230/242
-Ported/resurfaced 317 heads
-100% alky meth injection
-1 7/8 American Racing headers with full exhaust
Old 01-12-2016, 07:14 AM
winters97gt
winters97gt's Avatar
Stock stroke, no meth?
575ish. 625-650 with meth. Put a 3.125 pulley on there and add meth, should make 775-800
Old 01-12-2016, 09:57 AM
95rtturbo
95rtturbo's Avatar
I would say ~675 WHP with that setup. For reference, I have similar mods on my Z16 ZO6, but with stock 243 ported heads, and ID 850 injectors, and put down 709 WHP with a 3.8" pulley, which produced 13 peak PSI.
Old 01-12-2016, 11:12 AM
nullpointer
nullpointer's Avatar
What type of dyno?
Old 01-12-2016, 11:35 AM
95rtturbo
95rtturbo's Avatar
Originally Posted by nullpointer
What type of dyno?
Shows dynojet in his post.
Old 01-12-2016, 11:42 AM
nullpointer
ahh missed it
~650
Old 01-12-2016, 12:20 PM
Josh@AandASuperchargers
Platinum Supporting Vendor
Josh@AandASuperchargers's Avatar
699rwhp
Old 01-12-2016, 04:44 PM
Despicable Z
Despicable Z's Avatar
685rwhp
Old 01-13-2016, 08:47 AM
Robert 2000
Robert 2000's Avatar
I would guess upper 600s to low 700s. You have a forged block pulley it down max out the Ti trim and let it eat!
Old 01-13-2016, 09:12 AM
95rtturbo
95rtturbo's Avatar
^ Agreed! I'm curious to see what the OP's peak boost is... He is running a smaller puller than me (I am running a 3.8"), and I maxed at 13 lbs of boost (709 WHP). Question for Josh @ A & A... At what point would it be advisable to switch to an 8 rib setup from the stock 6 rib setup when pulleying down? 15 PSI?
The final numbers will also be dependent on what the OP spins it to - my 709 WHP was to 7000 RPMs, and it was pulling all the way. So, if the OP stops at 6500, it will be lower for sure. Should be able to reliably run to 7K with a built bottom end.
Old 01-13-2016, 12:55 PM
416yellowz
416yellowz's Avatar
It previously made 10lbs with a 4.0 pulley, so I'm assuming it'll make around 13-14 with the 3.6
I was planning on running a smaller pulley, but it's just my little DD with a stock rear & trans so I didn't want to push the rest of the car too much haha.
I was hoping to see at least 650whp, so I'm glad to see everyone thinks it'll break that!
Old 01-14-2016, 10:30 AM
Robert 2000
Yikes if its your daily. I wish you the absolute best of luck. Personally for a daily like that I would want 550-600 ish and call it a day. I have a G8 that I daily and I will keep that thing mild on the setup.
Old 01-14-2016, 02:03 PM
Detoxx03
Detoxx03's Avatar
Old 01-14-2016, 07:46 PM
lsxvette
lsxvette's Avatar
i had basically the same setup made 656whp on a mustang dyno and low 700s on a dynojet ..and that was a conservative tune car still able to get mid 20s mpg
Old 01-15-2016, 01:32 AM
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Support Corvetteforum!
MVP'S ZO6's Avatar
Somewhere in the upper 600s.
95rtturbo (01-15-2016)
Old 01-15-2016, 01:36 PM
95rtturbo
95rtturbo's Avatar
So any updates? When is your dyno tune session scheduled for?
Old 01-17-2016, 11:35 AM
C U IN REARVEIW
C U IN REARVEIW's Avatar
Same setup here....a&a ti trim blower,4" pulley made 7-8psi,100% meth (585whp ). Came with a 3.6" pulley and made around 13psi (iirc). Didn't want to run that much boost until I upgrade trans/diff (05).
To Dyno # guesses?
Old 01-17-2016, 03:00 PM
fisher auto
fisher auto's Avatar
637 similar tq...
Old 01-17-2016, 03:08 PM
95rtturbo
95rtturbo's Avatar
I doubt he will hit anywhere near 637 tq with stock cubes.
Old 01-17-2016, 07:36 PM
fisher auto
Quick Reply: Dyno # guesses?
