ISP Racing | Beltsville Maryland
Former Vendor
Hello all,
We are ISP RACING in Beltsville Maryland and wanted to formally introduce ourselves on the Corvette Forum. We specialize in modifying Chevrolet, Dodge, Nissan, Toyota, BMW, Volvo, Mercedes, Jeep, etc.... So anything that makes power and wants to make more power.
Here is a list of our services:
FREE DIAGNOSTIC for issues
Brakes & Rotors
Oil Changes
Coolant & Transmission Flush
Transmission Repair & Replacement
Tires & Tire Repair & Tire Rotation
Mufflers & Exhaust
Belts & Hoses
Car Heating & A/C
Steering & Suspension
Tune-ups
Engine repair & Engine Swaps
Custom Engine builds
Fuel Systems
Race Preparation
Standalone EMS, Boost Controller & Electronics Installation
Turbo and Supercharger kit Installs
Custom Turbo builds
Custom Dyno Tuning with AEM, HALTECH, ProEFI ECUs
Alignment (Hunger Alignment Rack)
We have a in ground Dynojet 424x All Wheel Drive Dyno that will fulfill your tuning needs or just show you the current numbers on your vette. We also offer a huge selection in aftermarket and stock parts for the C5, C6, and C7 Corvettes. Please feel free to call or email (recommended) us to get more information! We look forward to servicing the DC/Maryland/Virginia area! We support our Armed Forces/Military and offer discounts for you!
Infinite Speed and Performance Racing | 10780 Hanna St, Suite 1, Beltsville, MD 20705 | 301-937-8008 | www.ispracing.com | LEE@ispracing.com
Brakes & Rotors
Oil Changes
Mufflers & Exhaust
Belts & Hoses
Car Heating & A/C
Tune-ups
Fuel Systems
Race Preparation
Custom Turbo builds
Welcome to the Forum! Excellent group of guys who do top notch work. The owner, Peter, is a great guy who has a proven track record of building some killer rides across many platforms. Don't pass these guys up.
Former Vendor
Lee
Worst
Worst Ever! DON'T DO IT! Mediocre at best
Has absolutely no respect for customer's property!
He has cars in shop for years! never gets done, my car was there 4 years with a lot of excuses, and blame to others, not him, broken record! BS artist, knows enough to con you!
History:
Pulled dash, cut all wires to existing ECU, no markings on wires to show where they went. at that point I was hostage...
Said would not need to change sensors or relays, I did.
Lost Key when trying to tow out of shop.
Broke oil pump shaft, metal in oil, had to remove oil pan to clean.
Waited to order Timing cover, I ended up ordering.
Lost spacer for Pro charger, took over two weeks to get.
Lost oil that I delivered, I found later in shop.
Pulled oil pan multiple times, had to wait for new oil pan gaskets each time.
Lost custom distributor cover, I found later in shop after ordering/installing a new distributor.
Lost custom radiator cap, I found later in shop after getting new one.
Built two custom radiator fan shrouds that didn’t fit, you suggested to cut frame to make fit, I send original shroud to get upgraded.
Talked me into connectors that would mount on firewall, that don’t (had to make cover to mount, but wires not presentable).
Let Oil/fluid drip on hood of car, parked under another car.
Power steering bracket broke due to harmonics.
Tore custom upholstered seat, had to have seats re-upholstered.
Scratched custom exhaust that took over 6 weeks to get.
Front passenger side head light not popping up now.
Don’t know where relay for wiper door motor is, will have to check on lift. Don’t understand why wire was disconnected in first place.
Wiring mangled (mess) after installing new computer, may have been a factor with headlight and wiper motor.
Crank sensor damaged due to Crank wobble, put spacer in and waiting test.
Had to get solid state relay for fuel pump to work with ECU.
Solid state relay didn’t work, had to get 1500.00 fuel pump with controller, but not sure if working correctly.
Power now going to ground. Don’t know what is causing.
Power brakes locking up due to low power steering fluid, don’t know why it is now low. Hydro boost brakes now not working
Removed plastic cover on fenders to find 2 large chips in paint.
History:
