rxt clutch wear question
Old 01-03-2015, 10:55 PM
StealthFRC
StealthFRC's Avatar
Default rxt clutch wear question
anyone know how much meat is on the disc when new? i have my motor out and clutch out and I'm trying to decide if i should send it in for a refresh. its got about 8k miles on it but they definitely weren't easy miles.
Old 01-04-2015, 08:19 AM
BoostSlam
BoostSlam's Avatar
Not sure I factory specs but if you decide to get new discs I'll take those off yours hands!
Old 01-04-2015, 07:22 PM
Chicago1
Chicago1's Avatar
I have one sitting at my house brand new in the box. I will open it and take pics when I get home in a few hours from work.
Old 01-04-2015, 07:49 PM
StealthFRC
StealthFRC's Avatar
that would be great, thanks
Old 01-04-2015, 10:57 PM
Chicago1
Chicago1's Avatar
Hope this helps...This is brand new I just took it out of the box just for these pics. Let me know if you need anything else
Old 01-04-2015, 11:14 PM
StealthFRC
StealthFRC's Avatar
so its roughly the thickness of a quarter? thanks for the pics!
mine is the exact thickness of a quarter.
i may just send it in for a refresh its already out of the car and may save time in the long run. i plan on turning the car up when back together so may be a good idea
Old 01-04-2015, 11:36 PM
Chicago1
Chicago1's Avatar
Yup about a quarter sizes it's not as thick as I thought it would be for something rated to hold 1k..Me personally since it's out you might as well get it refreshed.
Old 01-05-2015, 08:35 AM
PEETYZ
PEETYZ's Avatar
Either one of you usinf the stock ls1 flywheel with this clutch? Any shims etc needed?
Looking to do it this winter
Old 01-05-2015, 01:37 PM
CamminC5
Support Corvetteforum!
CamminC5's Avatar
St. Jude Donor '15-'16-'17-'18
Be sure you ask Mcleod how backed up they are. You could be without a clutch for a while. My past experiences with them aren't that great. Customer service is not one of their strong suits.
Old 01-05-2015, 01:39 PM
CamminC5
CamminC5's Avatar
Mcleod says their flywheel is the same dimentions as a stock one, and doesn't need a shim. It never hurts to take a measurement though.
Old 01-05-2015, 01:41 PM
JoeyG
JoeyG's Avatar
Cruise-In III Veteran
Cruise-In IV Veteran
I had mine rebuilt last year and the turn around time was pretty quick, rebuild cost was like 60% of new including surfacing my billet flywheel.
Old 01-05-2015, 01:55 PM
Turbo-Geist
Turbo-Geist's Avatar
2017 C5 of Year Finalist
Same here. I have two RXT's and trade them out. I pull one out when needed and send it off for a rebuild and install the other one. I was surprised at how quick the turnaround time was on the last one. The one from the last combo will be going in for a rebuild soon.
I've measured the thickness of the pads before and will check and see if I wrote them down somewhere.
I run the SPEC aluminum flywheel that has a replaceable steel friction insert. It supposedly has the same dimensions as the stock flywheel. The RXT is designed to mount up to a stock flywheel, but there are better flywheel options out there.
Old 01-05-2015, 02:14 PM
slow ride
slow ride's Avatar
At the performance level you would need an RXT at I would just spring for a SFI unit. I don't like cast flywheels mixed with puck disks since you can slip the puck disk so much and build excessive heat for a cast flywheel. Sometimes this can cause cracking in the flywheel, etc. I would use the RST with a stock flywheel due to the less aggressive organic friction. I use a Spec billet steel flywheel with my RXT as it's a decent low cost flywheel. The only thing that matters is that its a flat type flywheel and the center bore is not so large that the pucks of the RXt don't touch all of the flywheel surface. I also recommend balancing both parts as an assembly.
Chicago1
Chicago1's Avatar
I didn't I have their flywheel..
I got my clutch in less then a week when I ordered
Old 01-05-2015, 03:48 PM
StealthFRC
StealthFRC's Avatar
I havnt had any issues with cs. I wasn't the one that originally installed the clutch so I ddidnt have the alignment tool. I emailed them and within 30 mins they responded with "what's your address and application" and sent me one for nothing, not even shipping.
I emailed the same guy and he responds writhing 15-30 mins. He said the turn around Time is 5-7 days from day recived.
Old 01-05-2015, 04:34 PM
PEETYZ
PEETYZ's Avatar
Thanks guys. My current ACT single disk clutch has been fantastic but Im going forged this winter and wanted something a bit overkill that wasnt terrible to drive.
Likely will have around 700rwhp 600rwtq or so once forged etc but may want more =)
I ordered from site sponsor Colorado Speed today for a steal of a deal so we'll see. It's winter anyway so I don't need it now.
Sorry for the hijack OP.
-Pete
Old 01-08-2015, 02:20 AM
MVP'S ZO6
ISIS SUCKS FAT CHOAD
MVP'S ZO6's Avatar
Not the same manufacturer but it took me about a month to get disk from textralia USA. Not too bad but not lightening either.
To rxt clutch wear question
Quick Reply: rxt clutch wear question
