Gauging Interest TTIX Billet 6265 With 3" Downpipes
A trade deal has been made with a member so this is off the market.
This is a complete kit with all available upgrades and then some from TTI. Costs was over $13k a few years ago.
Billet BB PTE 6265 Turbos
TTI 3" Downpipes
Larger Intercooler Upgrade
These kits with low backpressure setups have boost control issues. I've gone to hell and back, and we solved that issue. TMK TTI has not addressed it. We welded up the downpipe WG port and added a flange to the housings. I also upgraded to Tial 44mm wastegates. Boost control is a non issue, and it still made 24psi with 11psi springs. I made 980rwhp through 2.5in mufflers. I've got dyno sheets, install pics, dyno videos, etc. Also have references for sales.
The kit is still on the car. The car is down for a stuck lifter. It would be 100% complete. It's in very good shape, about 5k miles. Just your typical dings or scratches that are bound to happen with install.
PM me on here for my cell if you would like more info or just reply here.
image by ls1x2, on Flickr
TTI 3" Downpipes
Sorry to hear about the lifter. Good luck with the sale on the TTiX kit. I bought mine used with 5,000 miles and it has been flawless for another 20,000 miles so far.
The person that purchases this setup will be getting a well sorted kit capable of making from 500 to over 1000 HP.
I'm itchin to crank up the boost but am reluctant to if it means grenading my dirveline in short order.
I'll add that for the "right" blower setup I'd be interested in a trade/partial trade. I'm going to need some 1 7/8" headers and a blower kit with better than off the shelf kit parts with a novi2000/2200,f1a/f1c, ysi, etc. I plan to dial the car in around 700 until I get bored and leave just a little room to turn it up. Prefer someone semi-local.
Good luck with the sale/trade. I'm sure it will get picked up pretty quick. The ttix setups never last too long in the for sale section.
Sad to see you sell and switch back. What was the rock bottom boost you could run with the gates in the new locations? I need to get moving on mine to see if my goofy gate location works well or not. Good luck.
I was running 6.5psi with only 10* timing in it with the new 416. Only got to try it a couple times, and then this damn lifter got stuck.
It's the billet 6265's with the CEA wheel rated at 700hp each. http://www.tunergeeks.com/products/product122.html
I've seen people make 1200-1300rwhp on here. Backpressure seems to be a major issue, so assume straight 3" with no restriction.
can you tell me a bit more about the boost control issues. wish I could afford the kit, I'm working on a TT project right now
I have the champion 3" down pipes I'm getting ready to install
Tiago and Forced Fed Fabrications devised a solution where we drilled a hole in the bottom of the housings. We attached 44mm tial wastegates there. Problem solved. I'm looking for a pic.
