***Hinson Motorsports Engine Mounts In YELLOW!!! Limited Time Only!!!***
Former Vendor
The Hinson Motorsports Mounts You All Know & Love Are Now IN YELLOW!!!! LIMITED SETS ARE AVAILABLE !!!
IF YOU WANT A SET OF THESE THE ONLY WAY TO GET THEM IS TO CALL US BEFORE THEY ALL SELL OUT
205-909-9402.
$195.00
205-909-9402.
$195.00
MADE IN THE USA!!!
These ARE THE SAME MOUNTS YOU KNOW IN LOVE IN YELLOW. Dont miss your chance to be different with your engine mounts. We started experimenting and look at what we did. These are only offered in standard height and we only have a few sets. If you like what you see comment below on what you would like to see us experiment with next!!
Features
* Designed for street and race cars
* Direct replacement for stock rubber mount
* Uses factory metric nuts (not included)
* Stainless Steel construction for rust free operation
* Interlocking design for fail safe operation
* Uses factory heat shield (factory heat shield is required)
* Fast installation
Former Vendor
No definitely not. They are a performance mount but not harsh enough to shake you to death or feel every little thing. They simply offer an interlocking rigid design that stabilizes and secures the engine better to the subframe. We also offer transmission mounts as well and they can be bought as combo packs in order to save a little $$$. They are also offered in a shorter low profile version to offer a little extra hood clearance. If you are interested in the yellow ones particularly jsut specify in the notes when you order you want yellow. The only difference is the color. At this time quantities are limited and they are only available in the standard height.
Engine & Transmission Mounts Short, Standard, & Combo Packs
