Help pricing a procharger kit
I have an ATI stage 2 procharger kit off an 2001 z06. It comes with everything to bolt it on, plus injectors. It's in good shape with no shaft play or impeller knicks or bends. Whats the kit worth and will it work on an ls1 c5?
It should work on any C5 or C5Z from what I remember.
Assuming the kit is complete and in good shape I would say it is worth about 3k or so. What is the head unit? P1 or D1 etc?
Thanks for the reply, PEETYZ. The head unit is a P1 headunit. Everything seems to be in great shape and working fine as I drove the car 3 hours back home.
Around $3000 for a used entry-level type of kit seems to be the norm. If it was in exceptionally good condition with low miles you might get a little more.
Why did you take it off? You do know you're going to want it back on shortly right?
I took it off to go a different route, I had a C5 with an A&A kit on it last year and loved it. I'm going to try something different this time though.
