Rebuilding the Ghost, aka Great White
Old 08-10-2014, 11:50 AM
Turbo-Geist
Turbo-Geist's Avatar
2017 C5 of Year Finalist
Default Rebuilding the Ghost, aka Great White
As mentioned in another thread, the engine failed in November of 2013. I had been buying parts for almost a year and hoped that the LS1 would last well into 2014. It didn’t and then the only thing useable on the “running LS2 engine” that I bought was the block. At that point, I figured I may as well take things a step further. I'll try to document the bulk of the combination here in this build thread.
There are still quite a few things left to do and hopefully it will be running before the end of the year. Either way, I'm not in any hurry. On to the details...
Partial Pile O’ Parts
Engine: 6.0L Aluminum LS2 from a TBSS
Block Work by: Race Engine Development
•Installed Darton Seal Tight Dry Liners and Stress Relieved Block
•Finish Honed block with torque plates for Wiseco pistons
•Step decked Block, sleeve flanges are .0015" proud +/- .0005"
•Rethreaded head bolt holes for 1/2" head studs
•Installed HTC Steel Main Caps
•Align Bored Block for steel main caps
Block as received from R.E.D.
Darton - 4.125” Bore - Dry Sleeves
HTC Billet Main Caps and ARP Main Studs
Old 08-10-2014, 12:07 PM
Turbo-Geist
Crank
Lunati Signature series for GM LS GEN III/IV
•Stroke: 4.000"
•Main Bearing O.D.: 2.559"
•Rod Journal O.D.: 2.100"
•Rod Journal Width: 1.900"
•4340 Alloy
•24 Tooth Reluctor
Pistons
Wiseco 2618 alloy forged pistons; kit number K443X125
•Bore: 4.125"
•Comp Height: 1.140"
•Avg Weight: 446g
•Volume: -23cc/Dish
Rods
Lunati Pro Series connecting rods
•C-to-C: 6.125"
•B.E. Bore: 2.225"
•P.E. Bore: .928"
•Weight: 641g
Old 08-10-2014, 12:08 PM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
Default ttt
Great base and start buddy on the new rebuild for the car.
Old 08-10-2014, 12:16 PM
Turbo-Geist
Here's a little note about the piston and rod combo. Wiseco's catalog lists this piston as having a 1.140" compression height and compatible with a 6.125" rod length. This stack up will put the piston ~ 0.030" out of the hole with a nominal block height of 9.235". This wasn't acceptable for this build and the machinist had to take 0.030 off the tops of each piston to get back to the right clearance for this build.
Old 08-10-2014, 12:27 PM
95wht6spd
95wht6spd's Avatar
Nice. What is the overall plan?
Old 08-10-2014, 12:38 PM
mdaniel
mdaniel's Avatar
To go fast.
AtlasInTheGym (11-08-2016)
Old 08-10-2014, 12:44 PM
JDS99
Support Corvetteforum!
JDS99's Avatar
Nice pile o' parts Ben!! Looks like there's been some thought put into it for sure.
I can't help but notice the precision box in the top right. Those wouldn't happen to be new snails for the ttix would they?
Any details on the rest of the rebuild plans? Heads? Converting to FAST intake?
Old 08-10-2014, 12:45 PM
Turbo-Geist
Thanks, Robert.
Planned use is multi-purpose. Drive to the track-run 8's-drive home with a 6-speed, race at Texas Invitational, cruise to in-town and out of town car meets, attend half mile and full mile events in state and out of state. I may even take it back to the road course again. Basically use the car the same way I have for the past 5 years, but with more power and finally run a half or full mile event.
Old 08-10-2014, 01:21 PM
Turbo-Geist
Originally Posted by mdaniel
To go fast.
Good answer.
Thanks, I'll post up some more details. Turbos are the Precision billet 6265s. The FAST box contains a stock ls7 intake. I got it used for a great price.
Old 08-10-2014, 01:27 PM
Turbo-Geist
Cylinder Heads
GM LS7 Cylinder Heads
Head Work by: West Coast Cylinder Heads
•Competition Valve Job, Bronze Valve Guides
•Minimum Resurface of Deck
•REV LS7 1.615" Inconel Exhaust Valves
•BT Platinum Dual Spring Kit BTR-SK001
Combustion Chamber
Intake Port
Exhaust Port
Old 08-10-2014, 01:32 PM
Turbo-Geist
Here's what will provide a "boost" to all the previous parts listed:
Turbos
Precision PT6265 Ball Bearing Turbos
•Precision 'B' cover
•Turbonetics 0.82 A/R 5 bolt turbine housings
•Exclusive CEA (Competition Engineered Aerodynamics) compressor wheel machined from a 2618 aluminum forging
•Compressor Inducer: 62 mm
•Compressor Exducer: 82 mm
•Turbine Wheel diameter: 72mm
Billet Compressor Wheel
Downpipes
Champion Motorsports 3 inch down pipes
•Full 3” Stainless Tubing
•Custom built for C5 w/ TTiX kit
Weld Detail and WG Routing
Old 08-10-2014, 01:39 PM
slow ride
slow ride's Avatar
Cool, never seen precision 62's in a B cover. Did you have to ask nicely
Old 08-10-2014, 01:57 PM
Turbo-Geist
I ordered them through Turbo Technology. They have always been helpful through the years even though I bought my kit used from an individual. They have the jigs for getting the elbows welded on correctly and squaring up the flanges on the turbine housing. These should provide the power I'm looking for now and then if desired, I'll do something custom down the road.
Old 08-10-2014, 02:05 PM
JoeyG
JoeyG's Avatar
Cruise-In III Veteran
Cruise-In IV Veteran
Awesome parts list/stockpile
Old 08-10-2014, 02:23 PM
Turbo-Geist
Thanks. It seems like it's been a piece at a time as the months have passed by. The last thing to manage is getting it back from the machine shop. Then it will be up to me to find the time to put it all back together, tune it and make sure it's ready to rip.
The build is it's own kind of fun but I really enjoy driving and racing with minimal downtime.
Old 08-10-2014, 03:06 PM
ajrothm
ajrothm's Avatar
Received 1,095 Likes on 746 Posts
Congrats Ben! Glad to see it all coming together.. FINALLY..
Gotta love a TT 427!
Gonna do the TR6060 swap now as well while it's apart?
Old 08-10-2014, 03:41 PM
Turbo-Geist
I have no choice. I sold my rear diff to Bill after purchasing a low mileage TR6060 and C6Z Diff from an '09 Z06 last year. It's been collecting dust waiting to be mated up. The stock C5 trans and diff was rated at 385 ft-lbs of torque. The only upgrades were a DTE brace and DSS 300M shafts. They survived 800 ft-lbs of torque and 1.5x 60 foots at the track. I'm planning to use the same formula here. I've purchased an ECS Trans brace and may add DSS shafts if needed.
'09 C6Z TR6060, Rear diff, and Cradle assembly
To Rebuilding the Ghost, aka Great White
Old 08-10-2014, 04:04 PM
Chris Stewart
Chris Stewart's Avatar
Schweet!
Old 08-10-2014, 09:39 PM
b16gsr
b16gsr's Avatar
HELLL YES, looking forward to seeing this come together.
Old 08-11-2014, 12:38 AM
BLOWNBLUEZ06
BLOWNBLUEZ06's Avatar
I just love build threads!
Suggestion if you don't mind:
Have your reluctor indexed and TIG welded. I've seen too many moved reluctors lately. It's good, cheap insurance.
Subscribed!
Quick Reply: Rebuilding the Ghost, aka Great White
