Going to the dyno saturday. Anybody want to guess numbers?
08-01-2014, 12:40 AM
Location: Piedmont, SC Currently Own: 99 Nassau blue FRC. Previously Owned: 84,95,98 Indy Pace,01 Z06
I recently installed a procharger p1sc-1 with a 4.38 pulley. I have a ecs big blower cam, along with kooks headers with high flow cats. I do have a racetronix fuel pump and harness running 80lb injectors. Before procharger, I was at 408 rwhp. I'm thinking this pulley may be a little big and only net me around 5lbs of boost. Either way, what would be your guesstimate on power. May pulley down as I would like around 8lbs. Complete Mods are in my sig.
08-01-2014, 10:38 AM
08-01-2014, 11:21 AM
Id definitely pully down to run around 9 psi. You can easily get to 600 wheel with all the supporting mods.
08-01-2014, 01:18 PM
Which dyno?
Rocks- 580's
Hawks- 520's to 530's
08-01-2014, 01:30 PM
550ish, that pulley should be around 5-6 pounds.
Dual ICs or FMIC?
08-01-2014, 02:51 PM
ISIS SUCKS FAT CHOAD
08-01-2014, 03:57 PM
Dual IC's. It will be at Rocks.
08-01-2014, 04:02 PM
I'm hoping to be around the 560 mark at least.
08-01-2014, 04:07 PM
540-570. Keep us posted
That is a pretty big pulley tho. If you can go down to atleast a 4.0 I think you would be 570+. 3.85 Hit the 600+ for me with similar mods
08-01-2014, 04:23 PM
08-01-2014, 04:42 PM
Quote:
Originally Posted by
4DRUSH
571-1000
Never a dull moment
08-01-2014, 05:02 PM
4DRUSH
571-1000
I'll take that category!
08-01-2014, 05:22 PM
Cruise-In III Veteran
Cruise-In IV Veteran
4DRUSH
571-1000
With a huge fun smile factor
08-02-2014, 12:14 PM
With that pulley, cam, and headers it might be a challenge to hit 5psi.
525rhp
08-02-2014, 03:06 PM
Results are in! I pretty much got what I was looking for with the ferris wheel pulley I'm running. I barely was making any boost until around 6k rpm. Time for a smaller pulley though. Anyways I made 557 rwhp and 478 rwtq.
08-02-2014, 03:47 PM
Not bad, car looks nice also
08-02-2014, 03:50 PM
I think those are excellent results with that pulley!
08-02-2014, 05:07 PM
Thanks! I thought so too.
08-02-2014, 06:30 PM
Good #'s, and a gorgeous color car
08-02-2014, 07:38 PM
JoeyG
