Real measurement for IAT and meth nozzle location???
After many many trouble i will finally begin the install of my blower setup.
I ll be running the maf, a single meth nozzle with a seperate IAT sensor with the casper maf/iat breakout harness to make it clean : http://www.casperselectronics.com/st...oducts_id=1108
What should be the minimum measurement between :
TB and IAT
IAT and Meth nozzle
Meth nozzle and TB
My plan was to install the iat the closest possible from the tb than leave 4 inch and install the meth nozzle than with the remaning space, the maf.
What do you think??
Eric
TB and IAT
IAT and Meth nozzle
Meth nozzle and TB
What do you think??
Eric
TB and IAT
IAT and Meth nozzle
Meth nozzle and TB
What do you think??
Eric
TB and IAT
IAT and Meth nozzle
Meth nozzle and TB
What do you think??
Eric
Well yeah, if you read my thread you can see that i ve put it exactly that way:
TB, IAT, Meth nozzle ,maf
Im only concern with the measurement between all those parts.
Again: iat the closest possible from the tb than leave 4 inch and install the meth nozzle than with the remaning space, the maf
Ok or not ?
I mean is there any precise measurement ???
Eric
Ok or not ?
Eric
ISIS SUCKS FAT CHOAD
This is a subject of great controversy. what i'm about to say, I haven't verified with testing myself it's just a theory. with such I could be off base but here's my thoughts. GM has them built in to the MAF on some setups and others are 4-6 inches in front of the throttle body. your heading in the right direction having the IAT after the Meth nozzles (for obvious reasons). with that said, I have mine mounted in the back of the intake manifold. I did that because I think there would be a measurable difference in air temperature from a point 4-6 inches before the throttle body vs the air temperature at the back of the intake manifold. and either way you mount it, its not difficult to do. I believe that you want to know what the air temp is entering the intake runners or even the cylinders but we do not have that ability with the stock ECM.
im about to crap on everything I said, but in most applications the 4-6 inch IAT mounting gap post meth nozzles is probably good enough.
out of curiosity, how much boost do you plan on making? you may want to consider ditching the MAF all together and doing a Speed Density Tune.
I ll be boosting 7-8 psi max on my 11:1 cr 383 with a 240/244 (.62x/.62x ) @ 113 lsa wich is not a blower cam.The meth (50/50 is only gonna be there to keep the iat low (about .5 AFR) not to boost the timing
awesome!! I think your going to be at the ragged edge of wanting to go SD. The car should make 700 WHP with that static compression ratio.
I have the caspers harness also. Here is what I have iat's in the high 70 low 80 range if I remember correctly. It's about 4" from the iat. You can see the iat sensor then the nozzle is on that same pipe look to the upper left you ill see the brass nozzle...
edit here is a better pic..
Thanks for the info and pics
Is it better to mount the iat horizontally or vertically ??
my understanding is it doesn't matter and my temps are dead on every pull with the meth activated..So I'm good with it all it is is a sensor it shouldn't matter not like a meth nozzle or pump which is injecting some type of liquid. I could be wrong but this works for me
Bringing this one back up.Im about fininshing the install and im messing with the intake pipe.
I wont be able to get the meth nozzle 4 inch before the IAT...About 2 - 2.5 or maybe 3 inch if im stretch everyhing.
I would cut the intake pipe just after the bend but i need to leav at least 1 1/8 of pipe to be able the get a good clamp.
Is it still gonna work or im just about to mess everything...
I installed mine in the intake manifold, right behind the TB. The meth nozzle is about 8" In front of the IAT sensor. It has worked great for me. You can tell on the dyno the intake temps dropped a great deal like 40* or so.
Bryan
The meth line is going in about the middle of the pipe, before the TB.
Bryan
Bryan
Bryan
Eric
Eric
Received 1,261 Likes
you could use a little jb weld around the iat to help it seal and keep it from coming loose, that's actually what I did with mine but it's under my charge pipe right before the throttle body... I drilled a hole slightly smaller than the iat sensor and just tightened it to thread itself and used some jb weld around the outside edge just for peace of mind... my meth nozzles are at the front of my charge pipe just after the bend in about the 10 and 2 o'clock positions, I would say they are a good 5-6" away from the iat sensor... mine has worked great so far, when logging my iat's drop about 40° once the meth starts spraying full blast
I mean i would use Lock Tite professionnal thread sceller (purple) but if i put something else like urethane or jb weld the sensor will be hard to take off ...no ???
