Boost question?
Old 07-26-2014, 03:17 PM
sfc rick
sfc rick's Avatar
Default Boost question?
So I'm often asked what boost am I running? Honestly, I have NO CLUE! So I installed a gauge and I still have no idea. Give my a direction and information on how to find out.
https://www.facebook.com/photo.php?v...91351704461131
https://www.facebook.com/photo.php?v...75332465462990
Old 07-26-2014, 03:46 PM
Rookieracer
Support Corvetteforum!
Rookieracer's Avatar
Rick,
Whatever the gauge indicates at peak rpm under load, perhaps top of 3rd or 4th gear.
A non supercharged car, will not show any positive pressure on your gauge.
Old 07-26-2014, 09:36 PM
neutron82
neutron82's Avatar
Received 1,261 Likes on 1,056 Posts
I never watch mine while driving but my gauge has a peak recall and I use hptuners to log, it also shows boost
Old 07-26-2014, 09:54 PM
sfc rick
sfc rick's Avatar
I guess I need to run my HP Scanner and data log to see, forgot that I had it.
Old 07-26-2014, 10:35 PM
Blow Torch
Blow Torch's Avatar
Things are happing WAY TOO FAST once you get on it to try and look at a boost gauge. Just log KPA and do the math. It's fun to see how high I can get that purple line.
And whatever it is now in this hot weather, JUST WAIT until its around 40-50 degrees and see what it is then
Old 07-26-2014, 10:44 PM
_zebra
_zebra's Avatar
my gauge's right where i can kinda see it out of the corner of my eye... but then again, with a PD, it more correlates to throttle position, so i can usually have a good idea without looking.
it is a nice gauge to have to see how altitude/DA are affecting your airflow... or as my case was tonight, to correlate starting to run lean every time you get near positive pressure
To Boost question?
Quick Reply: Boost question?
