Give me fuel, give me fire, give me that
Which I desire
Currently have a stock V2 3.6 pulley. Will be going forged making over 650rwhp. What type of fuel upgrades do I need? Currently have 60lbs injectors and lpe pump . Do the rails have to be upgraded ? Thanks
01 Z with headers
01 Z with headers
http://kennebell.net/KBWebsite/Commo...rFuelRails.pdf
Received 1,260 Likes
I have a walbro in tank pump, 60lb injectors, racetronix fuel pump harness, and kenne bell bap supporting 720ish... I do have fast rails but I don't think you necessarily need those... I get between 60-65psi fuel pressure depending on how heat soaked it is and hold it all the way to redline... I think low 700's is about maxing that setup out... I was talking to my tuner about making some changes and he told me I have no more room so I'm gonna plan to do a big fuel system that way I don't have to worry about it again
How many of you have Methanol injection too with the single pump set-up? (as listed above)
Thanks,Matt
Thanks,Matt
whoops I forgot about that, I am running a dual nozzle meth kit
kenne bell put together a good article on upgrading fuel rails.
