A&A on Ls6
Old 07-17-2014, 12:08 PM
turk2gk
turk2gk's Avatar
Default A&A on Ls6
Hey guys I finally ordered my A&A v2 si supercharger. It will be going on an LS6 motor(stock bottom end). My question is to you guys is. What is the most Hp or Boost that can be put on these motors b4 I'll start having to worry?
Old 07-17-2014, 01:21 PM
NukeC5
NukeC5's Avatar
I plan to do the same someday. Going to run 9 lbs. I've heard of lots of people going that high on stock engines. 8 always seems the go to for safety though.
Old 07-17-2014, 02:24 PM
backnblack2003z06
backnblack2003z06's Avatar
With an LS6 A&A usually sends the 3.8 pulley. In my fathers stock engine Z with long tubes he sees 10 psi and makes 620 to the wheels. The longevity of the motor will pretty much depend on the tune. Some guys make 700 for years on a stock bottom, some blow up after a season at 550.
Old 07-17-2014, 03:15 PM
Smoove
Smoove's Avatar
787rwhp stock bottom end ls6.
Don't worry, You're good.
Old 07-17-2014, 03:28 PM
Yellow03Z06
Yellow03Z06's Avatar
I made 719 at 13 psi without the restrictor plate. I've since backed it down to under 600 with the plate and 10 psi. As long as the tune is good you should be fine. Also, meth is a good idea.
Old 07-17-2014, 03:58 PM
turk2gk
turk2gk's Avatar
Haha sweet! Are you on Meth?
Old 07-17-2014, 04:00 PM
turk2gk
turk2gk's Avatar
Thanks for the feedback
Old 07-17-2014, 04:35 PM
Smoove
Smoove's Avatar
nope, that was 93 octane, no timing(12 degrees), 11.5psi, no meth. It would have made more but we were out of fuel at 5600rpms. I have a piston on my desk(dude at works car) from an engine cause of a meth pump locking up...the tune was very reliant on meth...which I wouldn't recommend lol.
We all run E85 now mostly.
Old 07-17-2014, 06:11 PM
jmd1487
jmd1487's Avatar
nope, that was 93 octane, no timing(12 degrees), 11.5psi, no meth. It would have made more but we were out of fuel at 5600rpms. I have a piston on my desk(dude at works car) from an engine cause of a meth pump locking up...the tune was very reliant on meth...which I wouldn't recommend lol. We all run E85 now mostly.
Was that with just a BAP?
Old 07-17-2014, 07:01 PM
PEETYZ
PEETYZ's Avatar
IMO 600ish 10psi stock bottom no meth. 700 with meth or e85. Then there's people like Milan... 899 rwhp stock bottom E85... All in the tune and a bit of luck with your motor being a good one.
I'm stock bottom pump gas only 606/531 9 psi 3.85 Pulley P1SC1. (mods in sig)
Old 07-17-2014, 07:06 PM
jmd1487
jmd1487's Avatar
I have an 03 z06 stock(except for headers and catback) with p1sc procharger twin innercoolers. with 3.85 pulley and a boost a pump, but only seeing about 7.5lbs of boost, does that seem right? Or could I have belt slip?
Old 07-17-2014, 10:49 PM
idontknow
idontknow's Avatar
stock 03
D1 @ 14psi
93 + meth
longtubes
catback
700+ here
Old 07-18-2014, 03:00 AM
Milan
Milan's Avatar
I wouldn't worry until you start making over 700 whp
Old 07-18-2014, 11:52 AM
Smoove
Smoove's Avatar
negative. I have/had one but, never used.
Old 07-18-2014, 12:46 PM
p1bz
p1bz's Avatar
787whp, 93 octane, 11.5 lbs,12 degrees timing, no meth at 5600 Rpm's?
Wow....
Old 07-18-2014, 12:47 PM
Chrisrokc
Chrisrokc's Avatar
All in the tune and fuel. Running a 3.6 right now. Made 660 a couple years ago.
Old 07-18-2014, 01:38 PM
Smoove
Smoove's Avatar
Wow....
00 T56
05 LS6 bottom end
AFR 205cc box stock heads
Fast 90
Trak cam 233 237 .649/.598- 112
Precision p-trim turbos 68/69 journal (non billets)
Superflow dyno, south florida heat, we did everything we could take back off the power..it just kept making more. Ran it like this for a long time as a daily driver, as it was my only vehicle. No problems at all. The stock trans didn't even mind it. The diff(s)....not so much.
To A&A on Ls6
Old 07-18-2014, 02:32 PM
ajrothm
ajrothm's Avatar
Received 1,095 Likes on 746 Posts
My stock 29k mile LS6 had 10-11 psi running through it for about 4k miles before the typical #5 & #7 pistons broke ring lands.. It did make 622rwhp on a completely stock engine other then headers/x pipe.
10 psi, 13* timing, 10.4 AFR on meth....(11.2 AFR without meth).... Broke pistons on meth...
All of the other pistons were perfect, as were the head gaskets...Plugs looked great and no signs of detonation...--the #5/7 disagreed.
Old 07-18-2014, 08:42 PM
randyfl
Support Corvetteforum!
randyfl's Avatar
Stock Bottom end LS6 and long tubes A&A 3.4 pulley 625 RWHP. I have not installed my gauge package yet, but tuner said 13psi.
Old 07-24-2014, 01:26 AM
HCtotheMAX
HCtotheMAX's Avatar
Wow, i am sorry that happened. That is not nice.
Question:
After going through that and roasting #5/7, is there anything you would have or could have done differently with your setup to keep that from happening? Or get a warning so you could prevent it? Just curious as I am seriously looking into a supercharger setup for myself. Stock bottom LS6, has heads, cam, usual bolt ons.
JB
Quick Reply: A&A on Ls6
