DeWitts SPAL Fans ??????
#41
Received 1,762 Likes
I "WILL" disagree with the EWP from MEZIERE and the assumption they do not work at speed!
Mine is proof they do and always do, at a constant 55 GPM where can it go wrong -
Most people who track go to one of the Hi-Performance standard WP (can't remember the make name, sorry - it's at the top of my head and I just can't remember the name )
Either way the 55GPM EWP is good at speed and I have a full DEWITTS radiator and stock fans and during our Hi-Desert heat it works great.
Thanks,Matt
Thanks,Matt
#42
Check out this thread from ECS on the c6 fi section. Doug suggest the OEM wiring and grounding for the fans diminishes the fan output to cause many vettes to have heat issues even with dewitts radiators and spal fans.
http://forums.corvetteforum.com/c6-f...t-run-hot.html
#44
#45
#48
When they're on, they kick ***, unlike what I remember powered by stock wiring.
Maybe someone should do a rpm test hooking them up straight to the battery vs stock wiring.
Maybe the Spal fans require more juice to operate full speed?
If so, you could use the stock wiring to control relays that could provide the extra power needed.
#49
How about this to control the fans...http://www.saccitycorvette.com/COOLITv2.html
My Spal fans are powered by aftermarket 40 amp relays, 10 gauge feed & ground wires, controlled by the ECU.
#50
#51
Have u thought about running a push style spal in the front and move the tranny cooler to another location ,I know people who use the 55gpm ewp & they come with a 2 yr warramty with them, this os my cure for the summer heat in boost & I run 2 pull spals & a cut down rad too ,who the hell road races there c5 & run speeds of 100mph + for 5 to 7 hours a day ? So this is why road racers use mechanical pumps ? My *** ,get the meziere 55 GPM Robert 2spal fans & call it a day the only time I see these cars get hot is because there sitting At red light or hot lapping @ the drag strip if your running down the highway @80 mph these cars have a tendency to stay cool anyhow
#58
Here's my setup. With it, I don't even reach operating temp when driving on the highway.
- Opened up the front license plate area.
- removed the fog light shrouds
- modded the factory bumper
- modified the front frame section (the upper portion has been reinforced to make up for the loss of strength from cutting, not just boxed in)
- removed the rad shroud (my heat issues were on track, not stop and go traffic, so I was more concerned with airflow at speed)
- Dewitts rad
- 160 degree stat
- factory water pump
- Spal fan
- Setrab oil cooler
- Straight distilled water, with water wetter.
- ACP hood
- Jet hot coated headers
When everything's installed I have metal ducting that closes up the front openings so that the air is forced through the rad.
My Intercooler isn't installed in this pic, it's an ECS one, and sits front of both of these.
- Dewitts rad
- 160 degree stat
- Spal fan
- Setrab oil cooler
- ACP hood
#60
Received 1,261 Likes
so you have the cut down radiator and it has an integrated cooler so you have considerably cut down the capacity to begin with... I would try the fans first and have your tuner check the settings and if that doesn't fix it then you might consider getting the full size dewitts and either lowering your cradle or having the cross bar cut and rewelded to move the mounting points of the radiator down so your inlet will clear... I have a full size dewitts/spal setup, big ecs intercooler, 180 stat and it's mixed equally with dex/distilled water... I don't drive where I sit in traffic much but I have yet to see it over 200 when sitting at a light and when cruising it's usually 185-195... highest I've seen it was about 210-215 after a few back to back hard runs on the highway
