Who's running 317 heads w/ boost?
Old 06-02-2014, 05:43 PM
Dtownbrown
Dtownbrown's Avatar
Default Who's running 317 heads w/ boost?
Curious to see how much power people are making running the 317 heads and how much boost their able to squeeze through them?
I currently have a set on my 408 stroker and So far Iv made 733hp @ 13psi. But now I'm considering upping the boost to 20# and getting in the 900's. My heads aren't ported but are studded and torqued to 90ft lb.
Old 06-02-2014, 08:54 PM
RickyBobby
RickyBobby's Avatar
I am running un-ported 317's. Little different set up though...6.0, 2.3 whipple, 13 lbs boost, 4l80E, 607/672 on Mustang Dyno.
I've been told by a few they are a restriction at my level but have never been given an estimate on hp gain if they were CNC'd.
Old 06-02-2014, 09:26 PM
Dtownbrown
Dtownbrown's Avatar
I'd like to know what's the most power that's been pushed with non-ported ones.
Old 06-02-2014, 10:26 PM
_zebra
_zebra's Avatar
same here. i've been contemplating running ported 317s on my TVS LS1
Old 06-03-2014, 11:47 AM
5 Liter Eater
5 Liter Eater's Avatar
St. Jude Donor '11
Before I swapped heads I ran stock 317's to ~20# and made 880. When I took them off they wouldn't hold water in the chambers for too long (IE: When CC'ing a head) so they needed a valve job. I still have them in the shed. After swapping to All Pro's (and resolving valve float issues) I picked up ~40 RWHP.
Old 06-03-2014, 12:20 PM
Dtownbrown
Dtownbrown's Avatar
Nice. I'd be happy with 880.
Old 06-03-2014, 03:54 PM
Mopower2007
Mopower2007's Avatar
I've got CNC'd 317 heads with stock sized stainless valves on an iron block 403. It makes 895 rwhp & 731 rwtq on 20 psi.
APS TT kit with LG turbos.
Old 06-03-2014, 05:58 PM
GOTHAM VETTE
GOTHAM VETTE's Avatar
I have ported ones on a 347, with 14.7lbs of boost I'm making 720 rwhp. I run a bunch of HPDE's with the setup so I'm not pushing the setup to much.
Old 06-03-2014, 07:33 PM
PRE-Z06
PRE-Z06's Avatar
Received 2,054 Likes on 1,306 Posts
Our tuner's budget LS stang runs unported 317s as high as 30psi with a single 88mm turbo on 93+meth, through an unlocked glide it has been a best of 5.6@128 in the 1/8.
Old 06-04-2014, 05:29 AM
MawneeC5
MawneeC5's Avatar
I made 609rw on a forged 347 -3cc pistons with some cleaned up 317s thrown on. 14psi falling off to 12 psi with a single TC76 turbo.
Old 06-04-2014, 11:02 AM
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Support Corvetteforum!
MVP'S ZO6's Avatar
That's moving out for sure! !
Old 06-05-2014, 06:25 PM
JT FRC 00
JT FRC 00's Avatar
How was the midrange power with the 317's? I've been contiplating swapping out stock 241's heads with a set of 243's that I have but thinking about the 317's and raising the boost a little. Just not sure what would B better. Raise the compression a tad or drop it a tad and up the boost.
Old 06-06-2014, 10:02 AM
_zebra
_zebra's Avatar
in simple terms: more compression for quicker response or more boost for higher power (given the same cylinder pressure).
Old 06-06-2014, 10:28 AM
JoeyG
JoeyG's Avatar
Cruise-In III Veteran
Cruise-In IV Veteran
Same realm of reasoning as Zebra. My UPP twin Vette uses ported 317's on my stock LQ4 shortblock, because they were there. I was originally wanting ported 243/799's for better midrange power at the 1/4 mile tracks. But then again I'd be kicking myself running standing mile events and having to compromise between the increased compression ratio and the higher boost.
Old 06-07-2014, 02:07 AM
_zebra
_zebra's Avatar
sorry, it's hard to do an extensive search on an ipod, but you've seen better top-end results on 317s than 243/799s?
i'd be fine losing a little midrange to make up some top end with my TVS
Old 06-08-2014, 04:12 PM
LedfootLarry
LedfootLarry's Avatar
Not to thread hijack, but do you have ay pics of the whipple setup ?
Old 06-08-2014, 09:17 PM
mdaniel
mdaniel's Avatar
You can make big power with an LS1 or LS6 head without much effort. I remember an F-body car running low 8s ten years ago with basic LS6 heads.
The concern becomes keeping the heads nailed down.
To Who's running 317 heads w/ boost?
Old 06-10-2014, 12:51 PM
_zebra
_zebra's Avatar
x2
and remember that yeller C5Z that got the custom 3.3 strapped on a couple years ago? that one seemed fun, too!
Old 06-10-2014, 01:26 PM
breecher_7
breecher_7's Avatar
My buddy ran a set of cheap ported 317's on his old 364ci. Made 915whp on a eddy current dynojet @7000rpm and 21psi.
Id say they work pretty well.
Old 06-13-2014, 07:03 PM
RickyBobby
RickyBobby's Avatar
It's in a 1973 Camaro...not a vette, sorry.
If you still want to see pics, I can share.
little vid I made .
Quick Reply: Who's running 317 heads w/ boost?
