current cam "usable" SAFELY with an SC?
Old 04-25-2014, 01:22 PM
mre1974
mre1974's Avatar
Default current cam "usable" SAFELY with an SC?
Currently I have a Thunder Racing 224r 112 lsa cam with ported and slightly milled 853 heads waiting to go on my '99 ls1. The cam specs are 224/224 .563/.563 112 lsa. Heads were milled .030" I believe (need to check but too lazy to dig out the paper work). Previous owner of the set up was getting ~440 rwhp with other supporting mods (LS6 intake, ported tb, LT headers, high flow cats) on an LS1 F body. I've seen the dyno sheets and I know that the heads and cam on my '99 FRC will make it feel like a different car. But what I am most curious about is will that cam be usable SAFELY with an SC if I decide to go that route in the future? I realize that there are better SC cams out there but I really happen to like the sound and feel of the 224r and heads set up so not sure I want to get a different cam. Any insight to the pros and/or cons of what I am thinking would be greatly appreciated. Thanks in advance.
Old 04-25-2014, 01:47 PM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
Old 04-25-2014, 02:53 PM
MawneeC5
MawneeC5's Avatar
It will be fine. I ran almost the same cam in my 98 with P1SC and D1SC prochargers. Performed great!
Old 04-25-2014, 05:08 PM
mre1974
mre1974's Avatar
Thanks for the responses. Just curious...what kind of numbers were you putting down at the wheels?
Old 04-25-2014, 06:39 PM
dankhts
dankhts's Avatar
A well respected tuner on this forum always says that if a cam makes good power N/A, it'll make good power F/I.....even thought there a specific cams for F/I that'll make more ....
Old 04-25-2014, 08:29 PM
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Support Corvetteforum!
MVP'S ZO6's Avatar
More specifically a cam that makes good power NA will make good power in a centi or nitrous vehicle.
Old 04-25-2014, 11:01 PM
nullpointer
nullpointer's Avatar
I've heard that too but in my case my NA cam would turn into a valvetrain shredder if I put a blower on it.
Old 04-26-2014, 10:01 AM
madmatt9471
madmatt9471's Avatar
Location: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
It will work and it will need to be tuned in (of course) on the Dyno -
That is one heck of a choppy cam you got -
Me and my buddy just slapped a 113 LSA with duration in the 240's and 61x lift int. and 62x lift exh. - that thing is choppy and fat and sounds wicked!
Running it with a D1SC, 3.4" Pulley, 10.2:1 compression, AFR 205 heads, on a freshly built 347 motor and getting the break-in miles on it now!
I'm thinking he should be in the 760+ RWHP range easily! (Mine with a small baby blower cam and an A4 w/3.42 gears is hitting 734 RWHP)
Thanks,Matt
Old 04-26-2014, 11:08 AM
mre1974
mre1974's Avatar
Here is a youtube video of almost the same cam but from texas speed...yeah, it should be nice and lumpy and sound even more aggressive with my SLP Loudmouth pipes.
Old 04-28-2014, 05:34 PM
StatmanRN
StatmanRN's Avatar
As long as you aren't running into valve float with the current springs it should be fine. You have slightly more overlap with the 12 but not that much duration or lift.
I say run it. Its already there and paid for. you can always change it if you want more power.
Old 04-30-2014, 06:56 PM
PRE-Z06
PRE-Z06's Avatar
Received 2,040 Likes on 1,299 Posts
To current cam "usable" SAFELY with an SC?
Quick Reply: current cam "usable" SAFELY with an SC?
