ATI Procharger Question (GEN 1)
I have a 2001 Vert and it has what I believe is a Gen 1 twin intercooled Procharger with a 5psi pulley. It squeeks and it feels as if it is slipping under hard accelleration as it seems to only want to boost to 2-3psi , although can near 5K rpm hit the 4-5psi mark. I am guessing the alignment may be off. I have also heard of people using the A&A mount and having good results. Thank you for your imput and ideas.
Please contact us at 913-338-2886, or ts@procharger.com for more details.
Thanks!
ATI
It is worth going to later style bracket over the original Procharger set-up! either from Procharger or A&A's set-up!
Do you have any pics of your current set-up we can look at?
Thanks,Matt
