who all is running an EOCwith there charger?
Old 04-19-2014, 01:52 AM
fsuforever
fsuforever's Avatar
Default who all is running an EOCwith there charger?
I'm just trying to get an idea of what to get ,if anyone has some pics & would share how they routed the cooler would be wonderful. I know some rads come with the Engine oil cooler attached to it ,wondering how efficient they are?? And do you see a significant drop in oil temps? I just ordered another Dewitts short rad version & wondering if I should let tom know to make it with the eoc or just run the rad alone & maybe use a small eoc cooler separate &by itself? Thank everyone who chimes in & thank you for the feedback
I had this one laying around, never used it ,now that I've made the rad purchase ,I'm unsure if I should just install this one or let Mr Dewitt provide me one with the new radiator coming to me ? Somebody help me make a decision, also remember c5 not much room for this, I'm up in the air about which route to go,this particular heat exchanger is an earl pn 41310 ,13 fins its 4by 13 by 2 ,I will have to come up with brackets & -10 fittings regardless which route I take, thank you again for the support
Last edited by fsuforever; 04-19-2014 at 04:11 AM. Reason: needs periods & spelling corrected
Old 04-19-2014, 01:58 AM
Patches
Support Corvetteforum!
Patches's Avatar
Just received my cut-down DeWitts with EOC and matching short Spal fan setup. Not installed yet but looks good.
Old 04-20-2014, 02:20 AM
Phiber Optik
Phiber Optik's Avatar
I don't have any answers to your questions but I'm in the same boat and have been doing some research and found this
http://www.improvedracing.com/cooler...80f-p-369.html
I also already have a smaller heat exchanger that should work and feel more comfortable keeping both systems separate
Old 04-20-2014, 10:13 AM
jbsblownc5
jbsblownc5's Avatar
2017 C5 of the Year Finalist
St. Jude Donor '08
I run the shorter Dewitts Rad, with a sepperate Oil cooler mounted in the noise. I also have a dry sump setup. Do what ever you can to keep the path of air to your rad open...
Old 04-20-2014, 12:27 PM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
B&M oil cooler here with the fan on it.
Old 04-23-2014, 04:59 AM
MVP'S ZO6
ISIS SUCKS FAT CHOAD
MVP'S ZO6's Avatar
Ebay oil cooler, LPR oil block some braided lines and -10 fittings.
Works like a champ for me.
Old 04-23-2014, 08:41 AM
breecher_7
breecher_7's Avatar
Put a Setrab 625 Oil Cooler in the nose of my buddies YSI car last season, works to well...
Old 04-24-2014, 03:28 PM
RickClarke23
RickClarke23's Avatar
What about running the -4an line I have going to my blower to the front of the car to an external 4an oil cooler then run the other side back to the blower? seems like it would be easy enough?
Old 04-24-2014, 04:30 PM
breecher_7
breecher_7's Avatar
-4 line doesnt move even close to enough volume. Needs to be -10 - -12 to be effective.
To who all is running an EOCwith there charger?
Quick Reply: who all is running an EOCwith there charger?
