Ls1 power guesses
Ls1 power guesses
Hi everybody, so let me start by saying I have been building this for a little while and am hopefully gonna be done this week. But here is a list of my parts and I was wondering what you guys thought this combo would make:
Stock ls1 bottom
317 heads
Ls9 cam (proper springs and ls7 lifters)
Bbk ssi intake
Bbk shorties
2.5 x pipe no cats
Borla bullet exhaust
A&a supercharger d1sc with 3.6 pulley
60lb injectors
E85
Any guesses, not really looking to be told stuff will break I figure it will run until it won't. Just all around thoughts on power
Stock ls1 bottom
317 heads
Bbk ssi intake
Bbk shorties
2.5 x pipe no cats
60lb injectors
E85
My 1999 ls-1 with p1-sc on my stock engine accept headers with 3.2 pulley i made 550ish. So my guess is low 600's to 650 top. Good luck
My thoughts on why I have a stock fuel pump is, with a 40 amp boost a pump, which I know lots of people with similar set ups and the 20 amp make more than 550 at 8 lbs of boost. I had thought about a better pump however ls1 cars flow at 58psi out of the box and the boost a pump should keep it pretty consistent, with 60lb injectors which are rated at 43.5 psi with 58psi the should push 69.2 at 80% duty cycle. I am not too concerned with fuel starving at this point I might change my mind in the future, I know fuel pumps are cheap I think I will be good and in the low 600's. I could be wrong heck it might not even start and I will be at 0. Thank you for your thoughts
You didn't mention a hotwire kit or boost-a-pump so I guess you are trying to do this with a stock pump and less than optimal voltage?
If so, the 60# injectors and stock pump will limit you to around 550 rwhp or less. Let us know how it turns out.
Here's a quick update after a misserable time at the tuners I had 3 injectors go static and bought some 80 lbs ones from him. My knock sensors gasket decided to stop gasketing, if that's a word and sprayed oil everywhere. So we tuned as best we could, I will Dyno tune it there in a few weeks as long as more stuff doesn't break. I think I am going to add a 255 walboro also just because it makes sense.
Later that night I replaced the seal in Valley and on the knock sensors. So I decided y not try and drive it it's a got a decent tune, and now it actually feels slower. That makes zero sense it runs great it just doesn't launch at all and I back off before it get too lean. Anyone else have this problem with launching?
