How do I relocate radiator to fit Procharger kit?
I've looked everywhere. I have read some guys cut and re-weld the brackets farther forward or lower, but I don't have a welder or ability. Is there a way to do it with no cutting? I've seen mention of "L" brackets. Anyone have any pics of this? I don't want to have to cut and weld. I have a P1SC1 kit and I'm becoming overly frustrated with the fact that it hits the radiator. I bought my kit used so it doesn't have anything to relocate it. I believe it originally came with the Procharger fan assembly, but I don't have that either. Any help would be greatly appreciated. Especially pics!
Received 1,762 Likes
Are you can pull your stock one out simple to do and have a welding shop do it for you. If you do the work will cost much of nothing to have it done..
Yeah. I just didn't have a welder. I went out and got aluminum spacers to drop the actual radiator support. I dropped it 1" in the back and about 1/2 in the front. Worked out pretty well. Seems like it did the trick!
The original procharger kit with that fan intake was junk. Mine was also used and contained parts from original kit and "stage 2" with an A&A bracket. Mixed kits can be fun...A&A and ECS do a great job on the new kits
The big things you are missing are the radiator cover and cradle. My tuner modified some of the charge pipes and made new pipes from Y section after twin intercoolers into TB with LS3 style maf and also section from blower to filter (no more kinks) I also went with a tial Q bov.
I am using the stock shroud and all as of now. That pic was just for reference. I really would love to get the charge pipe you have in the center. I hate the Procharger "air bridge." That is a much cleaner, smoother look. But I am scared that the hood won't close. I dropped the radiator 1" because I don't want to spend $400 for the cradle haha. I want it to be clean however. So maybe that's what I'll have to do. But for now I just want this thing finished haha. It's been a long time coming. I'll eventually straighten out the kinks and do what you did along the way.
Very clean set up!
I have the HO (original) and stage 2 manuals as well if you need them.
-Pete
I really appreciate it. Mine came with the original manual. I was kind of shocked to find some parts of the stage II kit like you said lol. What kind of power did yours out down? I have a 4.25 pulley. Not sure how much boost that'll put out but I can't wait to get it tuned and see some numbers.
