Dual catch can: where are you putting them (with pics please)
Well im preparing my v3 si install and i was wondering since everything will be really tight where are you guys installing your dual catch can setup ???
Gotta nice saiko michi dual to install but just dont know where to put it ?
Pics would be nice
Pics would be nice
Received 1,762 Likes
ttt
No pic,s but some are running the can to the rear of the car behind the rear end. With a rubber hose down from the bottom.
I have the monster can and I put mine over where the batt was and now have mine batt in the cargo hole in the rear of the car...Robert
ISIS SUCKS FAT CHOAD
Bringing back my thread since im doing my install right now.
Any other member with a dual catch can mounted in the front of the car and kinda easily accessible.
Battery is in his stock location and will stay there
Eric
Eric
Received 1,261 Likes
I have a breather can mounted to the side of my radiator cradle, similar to post #2... I cut a small access hole in the panel underneath the drain spout and I can reach under the car and open/close it... I may eventually move it to the rear cradle but it's working fine where it is now
Eric
I had a -10an bung welded onto each valve cover and the hoses run along the frame on each side and under the radiator/condenser/intercooler cover... since you're using a catch can you will have more hoses to route but it's the same idea, just run the hoses the best you can that they aren't interfering with anything else and you should be fine
