9 PSI how long will it last at 13:1?
I know I know its a loaded question but here's the scenario:
Alky Control and Wideband both apparently bit the dust at the same time, or at least very close to the same time. I hardly ever drive the car but I drove it 5 or 6 times and a few wide open throttle pulls and apparently the Meth wasn't working because the pump has gone bad on me. I got my new wideband installed and it has been running very lean through boost at 13:1.
Tomorrow I plan to pull plugs and do a leak down to make sure nothing is hurt, but the car is driving fine and on the scanner appears normal. Oil pressure looks fine too.
I am getting a new pump from Julio Monday as well.
Any other advice you guys got to get me back on track?
I got a pressure sensor from Julio a while back and wired it into my HpTuners module for data logging methanol pressure. This setup helped me see my pump was going bad about a year ago.
Leak tested it tonight with results ranging from 10% to 13%...
I am going to keep going through it, adding some Brian Tooley Racing Springs, new methanol pump, and new Vortech seals.
Feels good to turn wrenches again!
Keep us posted with the results!
Come on down, we will take something apart on yours!
I am anxious to check my setup height on the springs, I think its setup too tall and not providing enough seat pressure. Hopefully I will have the car back up and running in the next week or so. I am going to try and video changing the seals on the Vortech to show the guys on here how to save themselves a buck or two on the rebuild.
