Drive shaft couplers - stock, poly or ?
Made by DSS and sold by RPM and others:
http://rpmtransmissions.com/newproducts.html
http://www.c5racer.com/catalog/c5-c6...FYtDMgod-BEA6A
http://www.floridaspeedandpower.com/...5-c6-corvette/
Here's a thread on both the DSS and Prothane versions:
http://forums.corvetteforum.com/c5-t...-couplers.html
Please don't do this unless it's professionally done to ensure it's drilled and threaded straight, and accurately located. Even then, I still would advise against it. For the money, you could just covert to 12mm tube assembly. Drill and tap the threads far enough out of tolerance and you'll be primarily loading one fastener over the next.
Not to mention you can't use a 12mm coupler in a 10mm tube assembly, they are different thicknesses and the assembled length will be wrong.
[QUOTE=JDS99;
Not to mention you can't use a 12mm coupler in a 10mm tube assembly, they are different thicknesses and the assembled length will be wrong.[/QUOTE]
What he said. Thickness is different. I did notice that using 2 zr1 couplers and a 12mm driveshaft make up the length difference to fit into a 10mm housing. Good for a spare I guess or slight upgrade over a standard 12mm.
Even stock 10mm bolt versions can take a beating if its a GM one or equivalent quality. It all depends on driving style, tracking, etc. all play a role in that will work for you. I've seen cheaper aftermarket couplers rub the tube from flexing to much. I think you can get GM ones for a little over $100 each.
My last set of 12mm DSS poly couplers had some very small rub spots when using the stock driveshaft. I think the stock shaft flexed enough under boosted 402ci loads. Hopefully no longer with the 3.5" DSS shaft in there now. Time will tell.
I'd like to know as well. I would guess that they machined the shaft ends to accomodate the thicker couplings if the ZR1's are thicker. Course, that would weaken the shaft ends slightly. Anyway, would be great to know what was done.
#33
The difference in size is just thickness from a 12mm stock vs a 12mm zr1. So they order a driveshaft just a little bit shorter to make the zr1 couplers fit.
#34
Just talked to rpm. They machine both ends of drive shaft, and the two flanges down.
Can u say MISSION!!!!
They Told me just do poly set up. .
Or second option is use the stock couplers and take it apart everytime it starts to crap out
#38
Yea but how do you know when it starts to crapout?
#39
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
This is how I could tell if they were going bad...
Generally there is a vibration that will start to occur in the driveline (at least with a stock driveshaft).
If a coupler is going bad, or a driveshaft is starting to bend...generally there is going to be a vibration and this is going to get worse with RPM. On a manual trans car this is pretty easy to test. With the car running, and in neutral (foot off the clutch) bring the RPM's up to say 3000 rpm, then 4000 rpm and if you feel a vibration push your foot down on the clutch. If the vibration goes away, then more than likely something is going on with the driveshaft.
Now that isn't to say it is a coupler going bad, or a bend in the driveshaft or something else...but at least it is going to point to the fact you better get the torque tube apart and check it.
#40
That's good to know at least I have something to look for. When mine went I was on the track and had been downshifting pretty hard most of the day, I could have caused the problem and had it go catastrophic all in that one track day which would explain why I didn't see any of the symptoms you outlined. Next time I pull the drive line out the sold ones are going in for sure.
