TR6 vs TR6IX
TR6 vs TR6IX
Is there a benefit of the NGK TR6IX (3689) over the NGK TR6 (4177) spark plugs for a boosted application (7 psi)?
TR6IX
http://www.ngk.com/product.aspx?zpid=10170
TR6
http://www.ngk.com/product.aspx?zpid=10168
Thanks!!
TR6IX
TR6
Thanks!!
I found this thread in LS1Tech:
http://ls1tech.com/forums/forced-ind...eat-range.html
It talks identifies various configurations (stock/aftermarket + nitrous/boost).
What I learned (I think) is that the TR6 plug won't even fit on my heads (Dart Pro 1) and with my setup (10.8:1 compression w/ 6.5-7psi) I'm going to need a much colder plug (heat range 8 or colder) than the TR6 for my setup.
According to this thread 11:1 requires a heat range of 8 (NGK R5672A-8). Should I go colder than that? 9 or 10?
Thanks for the help!
I pulled a plug to see what I was currently running:
BKR6EIX-11 (heat range 6)
I was running these plugs before the supercharger.
Does anyone see any problems with running:
BKR7EIX-11 (heat range 7)
Or should I just stick with the heat range 6 plug?
According to the thread:
a heat range 6 plug is too hot.
I know a lot of people run a TR6 with boosted applications but most of them aren't pushing 11:1 static compression ratio.
Thanks for the help!!
Why not just buy one of each and make a pull (dyno or street) and pull the plug to find out?
http://www.dragstuff.com/techarticle...ead-plugs.html
I like the iridiums for high boost. Car seems to run better too. Ran tr6/br7ef/etc and so far I like the 7ix the best for a daily driver 800-1000rwhp.
