Blown turbo(s)
Blown turbo(s)
Hey guys, long time lurker here.
I've ran into an issue with my '02 Z with a Stage 1 LPE TT kit on it: I've blown the turbos. When towed to the nearest 'Vette tuner, the shop owner gave me more bad news: the hoses from the turbo to the IC are worn out due to rubbing from the front tires, the oil can behind the oil pan is bent up, and it needs a new serpentine belt, plugs, wires, and cradle bolts; all of this on top of rebuilding the turbos, which the engine has to be dropped in order to remove. The shop owner says it's more cost effective to turn the car back to stock specs and sell the turbo kit, with the difference being $4,000. Hell, I'm unsure what the best route to go with would be, as it's hard enough to source turbos according to LPE's specs (which they don't give out). It's not like I have several thousands of dollars to dump into the car, but I can't just leave it as is. Thoughts?
Im sure it's probably not cheap to rebuild the turbos or replace them, but I would get another shops opinion before I gave in, after driving a car that got some power it's going to be tough to go back to near stock power.
I could never be satisfied if I went in that direction.
Get a second opinion. Turbos can be repaired the majority of the time and then there is that time it's cheaper to buy new ones. All the other things can be repaired as well. No clue why the price is so high.
Wow, I'd leave that shop as soon as possible. Turbos can be rebuilt by the manufacturer, and the rest is tuneup, maintenance, and misc items. Get it home, turn some wrenches and save big $$$
#2, I would have to see the damage, but I would almost be willing to bet that the silicone charge tubes can be spliced together with stainless piping and T-bolt clamps. If you need help with parts for the system, John Page, owner of 21st Century Muscle Cars (in Carrollton, TX) is the only Lingenfelter dealer other than Lingenfelter and he might be able to help.
#3 Dropping the cradle in these cars isn't difficult. I'm not sure where you're located, but if you want to wait and bring me the car, I can yank your cradle in a couple of hours or so, taking my time. If you're not close, many of us know good, reputable shops all over the country that can take care of you.
#4 I can't imagine how much your value would drop converting the car back to stock. Spending a bunch of money and keeping it a Lingenfelter might make more sense.
Don't go feeling stuck with the shop it's at. Tell them to hold off and do your due diligence on this before you pull the trigger at any shop you go to. We've all seen people get hosed and it sucks watching it.
They diagnosed a blown turbo without removing it? Find a new shop. If it's true the cradle needs to be dropped to get to the turbos, it could be anything at this point.
Better yet, post your location. Maybe someone on here can help you and save you some $$$.
Quality turbos don't just blow up unless you have a lot of miles on them (unlikely) or something else is wrong. Also turbo technology has come a long way since your kit was probably installed, let alone developed.
I'm in Maryland, as is the car. I feel like I'm stuck shelling out 3-4k to bring it to stock specs or 5-7k to bring it back to what it was. I wouldn't mind getting a second opinion, but I'd have to have the car towed to another shop if someone else was to take a look at it.
Also, if the turbos were replaced or rebuilt, it'd be the 2nd time that had to happen. The previous owner had the turbos rebuilt, as well as the charge tubes replaced. I'd say there was about 20k put on the turbos.
It's very difficult to own a complicated car like a tubocharged Z06 and not be able to turn your own wrenches when necessary. You either have to be able to work on it or have the $$$ to get it done. I would bet all you have to do is unbolt the manifolds and drop the exhaust to get the turbos out. The silicon can easily be ordered online. I think I have seen those oil return tanks on the lingenfelter website. There are probably other tanks you could make or resource.
I know I couldnt afford to have my car if I had to pay for labor and trust others to do things right. Hate to see a lingenfelter car go to stock.
Absolutely take it away from that shop! Much more value maintained by keeping it a Lingenfelter car!
If I remember right, the turbos used on most of them were Garrett gt2871r's. You can get a new cartridge or send them in for rebuild. Worn couplers, spark plugs, etc. are easy to replace. Can probably just get a new can from lingenfelter if needed or have someone replicate it. Any way you swing it, it's no where close to the expense you've been quoted.
unless the turbo blades have screwed up the housings they can be rebuilt cheaper than replaced or even get new ones cheaper than 7k
yes, it's a tough job to replace the turbos but I sure wouldn't take an LPE back to stock unless you really want to sell it bad and sell the turbo kit
even then, I'd think twice as the LPE turbo cars are a thing of joy!
You can have the turbos rebuilt at Arizona Turbo (AZTurbo) for about $300 each for a cartridge style turbo. That's assuming there is no impeller/wheel damage. The turbo will look like brand new when you get it back. Fast turn around time too.
Definitely fix the car and keep it a lingenfelter..
I'm curious as to why they think the turbos are "blown"... The odds of both turbos failing at the same time is pretty slim..especially with only 20k miles on them.
Find another shop or better yet, take it apart yourself.
many times either the turbo seals or the scavenge pumps fail which causes a bunch of smoke in the exhaust
unfortunately, it sounds like the shop is eager to spend your money rather than diagnose the problem which is a bit too common.
the LPE cars are generally very reliable, but if it has Ts or Tires, they are going to be issues
So I took it to a fellow Lingenfelter owner and forum member down in Alexandria; wish I had time to consult the forums first! Would have brought it to him right away. So the scavenger pump and pulley was absolutely ruined; the pulley was falling apart, and I imagine it's due to the scavenger pump seizing while the belt is still moving, tearing apart the pulley. Hopefully a rebuild, belt and new pulley will sort the problem out. Will let you all know how it turns out!
