Pusher system/NANO questions
From my perspective, to use a pusher system such as NANO you must have at least a 3-port valve. Valve1 - outlet, Valve2 - NANO inlet, Valve3 - Blowdown. Correct?
All 3 of these ports share the same path to the bottle through the tube, correct?
If you are using a pusher system, how does the contents of the bottle come up through the tube if the same tube is delivering pressure into the bottle from the pusher system??
Nitrous outlet is from the internal tube with opening at tbe bottom of the bottle. The blowdown connection has a pressure rated seal preventing flow until burst pressure is reached. The NANO connection is through a check valve screwed into the accessory port normally used for a gauge. This accessory port is at bottle pressure but as far away from the nitrous outlet tube connection as possible.
Received 1,762 Likes
