E85 with stock pump
Old 03-11-2014, 07:12 PM
long
long's Avatar
Default E85 with stock pump
Can a stock late '03 Z06 fuel pump be used with e85. I have the c6 style fuel system.
Old 03-12-2014, 04:32 PM
0FederalPerformance
Former Vendor
FederalPerformance's Avatar
Assuming you're not using stock injectors, you can. However no guarantees on the longevity of the pump.
Cheers,
Matt
Old 03-12-2014, 11:37 PM
fotoboy
fotoboy's Avatar
Ran the stock pump on e85 for 4 years with out issue.
Old 03-13-2014, 10:16 PM
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Support Corvetteforum!
MVP'S ZO6's Avatar
yeah man you can do it!! you can also run diesel in your car.
Old 03-14-2014, 12:10 PM
kromberg
kromberg's Avatar
Yes, but it will most likely not be enough to support anything over 450 to 500 rwhp. Remember E85 requires about 30% more flow.
Old 03-17-2014, 09:54 PM
MJD
MJD's Avatar
I have the same stock pump running e85. I run it with direct alternator power and a ken belle BaP. I'm about maxed out at 560rwhp.
Old 03-18-2014, 12:14 PM
FourG63 97GST
FourG63 97GST's Avatar
what are you guys running for a fuel filter.
I run a external pump also, with a mesh filter, but i'm concerned about the stock filter and E85. paper filter and E85, is a bad combo
To E85 with stock pump
Quick Reply: E85 with stock pump
