Installing NOS - how and where do I hook up the white wires from the TPS and MSD switches?
Topic says it all - I know I have to get to the pcm.....which wires and do I have to pull the front tire to do this?
[Modified by OliverM5, 7:36 AM 7/10/2002]
TPS and MSD switches? (OliverM5)
white wire from window switch goes to solid white PCM #10 pin.. at least on my '98.
TPS white wire goes to the blue wire on throttle body. The pass. side of TB. Splice in both.
Re: Installing NOS and MSD switches? (OliverM5)
OliverM5
When you pull passenger side wheel well cover off. You will find white wire Pin#10 under one of the grey covers held in place with one bolt in this picture. Other cover has no wire in pin #10. Ignore writing in this picture.
Use Dark blue wire on passenger side throttle body for TPS connection
[Modified by jetskifast, 5:53 PM 7/10/2002]
Re: Installing NOS (OliverM5)
oliverm5,
did it go well? I'm going to install the rpm window switch this weekend and wondered if you had any tips. thanks,
matthew
matthew
