*Clown has some tricks up his sleeve*
Old 12-06-2013, 01:21 AM
4DRUSH
4DRUSH's Avatar
Dave has his complete Novi 2500 set-up for sale, heads, cam, innercooler, etc. also.
Old 12-06-2013, 01:23 AM
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Support Corvetteforum!
MVP'S ZO6's Avatar
Whats Dave switching to?
Old 12-06-2013, 01:24 AM
a/c man
a/c man's Avatar
so clown got this combo??
Old 12-06-2013, 01:31 AM
PhysicsDude55
PhysicsDude55's Avatar
I'm pretty sure the only tricks the Clown has up his sleeve are some flowers!
Old 12-06-2013, 01:32 AM
4DRUSH
4DRUSH's Avatar
No, just removed everything last week, there's a lot more parts up for grabs also.
Old 12-06-2013, 01:35 AM
a/c man
a/c man's Avatar
where is the thread to some awesome parts?
Old 12-06-2013, 01:36 AM
4DRUSH
4DRUSH's Avatar
ECS YSI, (only reason NMCA doesn't allow the 2500 in Real Street class)
also going w/a innercooler, practically his whole kit is for sale
a/c man
a/c man's Avatar
thats good
Old 12-06-2013, 01:38 AM
4DRUSH
4DRUSH's Avatar
This is it (never got around to taking pictures, etc)
Dave made a vid of everything running before removal, but I can't find it.
Old 12-06-2013, 01:41 AM
4DRUSH
4DRUSH's Avatar
Originally Posted by Blitzkrieg
My car is down for the winter and I am not speaking of whats going on, all I will say is a 9 sec pass is coming…………………..maybe 8s………………….
Very possible
Old 12-06-2013, 01:44 AM
a/c man
a/c man's Avatar
Very possible
did clown threaten you with a knife made from a tooth brush to make this statement
Old 12-06-2013, 01:48 AM
MVP'S ZO6
MVP'S ZO6's Avatar
Very possible
I agree. He was running low 10s before. So. 9s is there forsure.
Old 12-06-2013, 01:52 AM
  #33
a/c man
a/c man's Avatar
Clown has you by knife point too I see made from bar of soap? no way he will ever see 9s with all that bling
Old 12-06-2013, 01:59 AM
  #34
MVP'S ZO6
MVP'S ZO6's Avatar
I think with the right car setup he could run 9s with that intake. The car already makes enough power to run the appropriate ET he just can't 60 foot the car. Cuz he has no suspension or tire.
Old 12-06-2013, 02:02 AM
  #35
a/c man
a/c man's Avatar
only if you put that heat sink pos on Jays car then it would go 9:99.9 in the 1/4.
Old 12-06-2013, 02:05 AM
  #36
a/c man
a/c man's Avatar
I run 9s on stock suspension and a 10'' wide M/T tire
Old 12-06-2013, 02:24 AM
  #37
MVP'S ZO6
MVP'S ZO6's Avatar
The key is the 10" wide mt tire. Clown has a 19" 345 nitto drag radials which well to br quite Frank are Probsbly the worst dr out there besides the BFG DRs Also u run 9s with quite a bit more power. Im sure your car 60 foots better than clowns too.
Clowns car dont 60 worth a poop. It is what it is. It makes the power to run 9s though. I think he ran his best time (the low 10 second pass) on a homemade drag pack and less power than he has now.
To *Clown has some tricks up his sleeve*
Old 12-06-2013, 06:04 AM
  #38
joshtownsend
joshtownsend's Avatar
dumb clown.. dont he know that everyone runs 9's even 8's in the 1/8???
Old 12-06-2013, 08:24 AM
  #39
breecher_7
breecher_7's Avatar
When the hell did you make this decision? Thats not what you told me yesterday...
Old 12-06-2013, 08:53 AM
  #40
digivex
digivex's Avatar
Below is a vid of my car from 11/23 (below), just before we began taking it apart. Took this to show that everything was working. Car ran 8.694 @ 149.03 on this setup with a 1.247 60'
Winter rebuild should improve those numbers a bit and make the car Legal to run in some events we missed last year.
Here's a partial list of what's coming off and may eventually go up for sale. I think I will be keeping the body, seats, steering wheel, the Haltech ECU (upgraded a bit), the block, the radiator, the fuel system, throttle body, headers, rims and tires
Some stuff from the Engine Area:
ECS Paxton Novi 2500 Supercharger system with ECS A/A inter-cooler, brackets, 10-rib pulleys (2.75 & 3.0), frame, plumbing / J-tube and charge tune, BOV, Wastegate, etc (basically a complete ECS Novi 2500 S/C setup for C5)- Also have a set of three restrictor plates, unless we can use these with the YSI
Complete (ready for install) AFR ported LS Heads with Yellow terra rockers
ECS Big Blower Cam
Set of 8 Injector Dynamics ID1000 injectors
Aeromotive Fuel Rails
FAST LSXr 102mm intake manifold
chrome plated C5 alternator
Alky Control dual nozzle Methanol System with two pumps and two sets of nozzles (two M15 and two M10 nozzles) - with new check valve / filters
Possible the Coils (although may want to keep these as backup)
Some Electronics:
AEM Failsafe Methanol gauge system with brand new AEM flow sensor and filter
Haltech Analog Dual wideband 02 with two AFR 02 sensors
PLX Devices combo AFR Boost gauge with DM 100 gauge and remote control
PCS D200 Dash ( http://www.powertraincontrolsolutions.com/product/D200/ )
AEM Boost Controller solenoid (possibly AEM Boost controller / gauge too)
Possibly: Gtech Pro EGS tachometer with Progressive shift light and Accelerometer Module: http://www.gtechpro.com/egs.html
Some stuff from the Suspension / Drivetrain:
Drag Ready, Fully Built, C5 3.73 Rear Differential, (like new - used only for Bowling Green), built by ECS with 500M shafts, DTE Billet Pinion Bearing Support, DTE Billet Side Cover, ECS spool kit
ECS adapters and Powerglide out shaft to convert PG to C5 rear
Pfadt carbon Fiber Drive Shaft for C5
Rear lower control arms with Pfadt bearings pressed in
Pfadt Coil over shocks (front and rear... fronts include both Drag and Street springs)
Pfadt Race Engineering rear Heavy Rate Sway Bar
Pfadt C5 rear differential Brace
ECS transmission Brace
ECS axle / half shaft safety loops
Possibly also for sale: ECS torque tamer (not certain yet)
Some Body type stuff:
Set of C5 rear Qtr panels (black)
C5 body side moldings (black)
Stock C5 Steering Wheel
Stock C5 Windshield Wiper system
Quick Reply: *Clown has some tricks up his sleeve*
