nitrous blowdown
nitrous blowdown
Anyone figured out how to mount the bottle in the cubby hole with a blowdown kit installed. I've got a NX kit and if the bottle is mounted with outlet pointing down then the cover to the cubby hole will not lay flat and latch down. I have removed the metal blowdown tube and put a 90degree fitting and a -4 hose to a bulkhead fitting to vent to the underside. Cover still doesn't fit flush. Any pics or ideas would be appreciated. :confused: :smash:
Re: nitrous blowdown (newberd)
N20 bottle siphon tube, is located at N20 bottle outlet fitting.
You want siphon tube, and bottle outlet pointed back at about 35 degree angle, like in my picture.
When you nail the gas, liquid N20 will flow to the back of your N20 bottle.
With my setup, you will use all 10 LBS of N20 in your bottle :cheers:
Added plus when you rotate bottle, you get more clearance for blow down fittings.
[Modified by jetskifast, 8:09 PM 7/8/2002]
It may make your tires smoke ....?
I just duno.............:D :D :D :D
:smash: :smash: :smash: :smash:
[Modified by bruce1, 8:50 PM 7/8/2002]
