Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Forced Induction/Nitrous
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection, Meth Sponsored by
A&A Superchargers
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-08-2013, 02:40 PM   #1
Gitusum
CF Senior Member
Gitusum's Avatar
rick traylor
Send a message via MSN to Gitusum
Default Auto trans question/ help needed
As some of you know i got my car back and after 8 days my level 5 trans lost drive and overdrive. Temp spiked up to 257 degrees on the tranny fluid and i have a trans cooler. I am going to be pulling the trans out this weekend and checking to see if the shop had kinked any lines etc ....
Now my question is this.....
Will a level 5 hold up good on the street with street tires not drag radials? Reason i am asking is my cash flow is super tight over all this build thats taken 3 years and alot of money. I called rpm and to fix it which they think is the clutches is $1000 and to fix it and upgrade it to a level 7 is like $1300 more.
Just wondering if any high hp auto guys have a level 5 and its holding up. By the way my hp is 826rwhp
Thanx
Rick
Gitusum is offline   Reply With Quote
Old 11-08-2013, 03:26 PM   #2
robert miller
CF Senior Member
robert miller's Avatar
Thanx
Rick
Rick I don't see your trans going bad on a level 5 that RPM put together. Unless the old shop did something to cause it on you like you said. It will cost you a lot more than the 1300.00 to go to level VII on c6 cradle then the plate that is 5/8 thick for 550.00 you need also.
Ship the trans to them let them do their work to it cause the art of these trans to live at these rwhp is the line pressure they set the trans up at to work like they do.. Robert
robert miller is offline   Reply With Quote
Old 11-08-2013, 08:34 PM   #3
a/c man
CF Senior Member
a/c man's Avatar
Just fix what you have and ask if they can do some tricks for a little more $ to make it last longer. We all know were pushing the 4l60 beyond its limit's
I wish I could fit a 4l80 in there!
a/c man is offline   Reply With Quote
Old 11-08-2013, 08:41 PM   #4
4DRUSH
CF Senior Member
4DRUSH's Avatar
This happen after a previous trans failure?
You stab the throttle in OD ?
4DRUSH is online now   Reply With Quote
Old 11-08-2013, 08:44 PM   #5
Gitusum
CF Senior Member
Gitusum's Avatar
rick traylor
no this is my 1st trans failure but i only had the car back 8 days and have been doing paint work on it 4 of the 8 days so only drove it 4 days total. and have never gassed on it over half throttle and in drive not od its just sad that the trans came with a 90 day warranty which expired still sitting in mayhem motorsports shop almost 3 years ago!
Old 11-08-2013, 09:00 PM   #6
BLOWNBLUEZ06
BLOWNBLUEZ06's Avatar
All too often, we discover that this disease of ours isn't any fun.
BLOWNBLUEZ06 is offline   Reply With Quote
Old 11-09-2013, 09:41 AM   #7
Gitusum
CF Senior Member
Gitusum's Avatar
rick traylor
so get the level 5 rebuilt or do i need to do a level 7?
Old 11-09-2013, 10:08 AM   #8
robert miller
CF Senior Member
Buddy the level 5 will do good for you with you doing the pull out with what you have said it was new when you took it to them look at your lines like you said on the car. Put money on it is something they did to it. RPM text ever one of the trans befor they ship them out. Robert
Old 11-09-2013, 10:53 AM   #9
Gitusum
CF Senior Member
Gitusum's Avatar
rick traylor
On a side note... I thought my rpm's were high going down the highway on the way home from mayhem in nc and i now see why.... I am almost 110% sure when i looked under the car when i had it back in december it had a 3.42 in it and now has a 3.73 in it!!! I never agreed to have a 3.73 rear in my car never wanted 1. 3.42 is as high as i wanted to go and expressed that from the very beginning of the build!!! With that said .. Seeing how other parts were switched out on my car every time the car was sent back i am willing to bet so was the teans and rear on this trip back!!! Now i am stuck with a rear i clearly do not want in the car!!
Old 11-09-2013, 11:12 AM   #10
alans02z
CF Senior Member
After reading your other thread, anything that has been done to your car wouldn't surprise me. Good luck with everything. Hopefully RPM can get it straightened out for you.
alans02z is offline   Reply With Quote
Old 11-09-2013, 11:18 AM   #11
robert miller
CF Senior Member
Buddy look at the trans and make sure it is still a RPM trans they put their decals on it plus use to paint them black. I hope it is stil a level 5 trans in it. But the 3;73 you can trade it out with someone in here due to the drag guys want the 3;73 now more than a 3;42 in the car for the track...
Old 11-09-2013, 11:44 AM   #12
madmatt9471
CF Senior Member
Support Corvetteforum!
madmatt9471's Avatar
Location: Palmdale, Ca----- 734 RWHP & 585 RWTQ-----1/4 10.34 @ 135 MPH (New ET Eventually!)
Thanx
Rick
Rick,
I have a Level V tranny in mine and at 734 RWHP -
However for just $300 more you can go with a Level VII I would do it, it is worth it to even borrow the money to do it!
If I were to go and up my RWHP to your level I would up to the Level VII myself - it is well worth it! A No Brainer!
Thanks,Matt
madmatt9471 is offline   Reply With Quote
Old 11-09-2013, 11:58 AM   #13
Gitusum
CF Senior Member
Gitusum's Avatar
rick traylor
Quote:
Originally Posted by madmatt9471 View Post
Rick,
Thanks,Matt
Its not 300 more its 1300 more and i have just confimed this isnt the teans and rear that was in my car when it was sent back to mayhem motorsports in january
Old 11-09-2013, 12:20 PM   #14
madmatt9471
CF Senior Member
Okay I misread then -
I thought it was $1000 for the Level V fix and add $300 to make it a Level VII making it $1300 total - Gotcha!
So in reality it is $1000 for the Level V and then add an additional $1300 to make it a Level VII making the total $2300 - I see now!
That's why I thought an additional $300 was worth it!
If the budget is very low then do the Level V and take any tranny lines going into the radiator out of it and bypass it straight into the cooler - that is what I have done and there are no heat issues ever!
No matter how good your tranny is built heat will destroy it thoroughly!
Thanks,Matt
Old 11-09-2013, 12:53 PM   #15
a/c man
CF Senior Member
a/c man's Avatar
So now your saying that you don't have the same rear end and transmission in the car? Is It at least a RPM??
Not all there trans are black some are not painted mine is just bead blasted. The servo cover will have a RPM decal on it.
Old 11-09-2013, 12:59 PM   #16
robert miller
CF Senior Member
Rick, that was what I was thinking from your post I don't see no way a RPM level 5 trans going out in what you where tell in the post. But again any thing can happen to something after just setting for 3 yrs.
You know what kind of luck your going to have with them when you call them about this.Robert
Old 11-09-2013, 01:04 PM   #17
danieloneil01
CF Senior Member
pipelinoperator
Lawyer up.
danieloneil01 is offline   Reply With Quote
Old 11-09-2013, 02:44 PM   #18
Gitusum
CF Senior Member
Gitusum's Avatar
rick traylor
Correct i had a rpm 3.42 now its a rpm 3.73 and from taking it out of the car they have been together for awhile which makes it true that both were swapped out and kept together. My other trans wasnt black it was like a blasted color. This current bad trans is a rpm but not the same one that was in my car a year ago! I will be posting some more backyard mechanic pics of the teardown later today
Rick
Old 11-09-2013, 03:10 PM   #19
a/c man
CF Senior Member
a/c man's Avatar
RPM stamps a LV for a 5 on the top bell side
Old 11-09-2013, 03:38 PM   #20
ajrothm
CF Senior Member
ajrothm's Avatar
Quote:
Originally Posted by danieloneil01 View Post
Lawyer up.
+1
Someone swapped some used/worn out sh*t in your ride... That's crazy!
__________________
10.59@127.52, ALL MOTOR
H2 Racing Forged/Iron 402", MAST 245s, ARUN STG 2 Cam, A&A Pro-Charger F1R, RPM Level 7 4L60e 9.96@149 w/m6, 9.22@151 w/auto
ajrothm is online now   Reply With Quote
Reload this Page Auto trans question/ help needed
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
96 c-4 auto trans preacher putz C4 Tech/Performance 3 07-06-2014 07:43 PM
RPM level 5 t-56 and level 3 diff for sale litz4244 C5 Parts for Sale/Wanted 8 12-16-2013 09:33 PM
Strange TransmssioFluid Leak chstitans42 C3 General 17 07-09-2013 05:38 PM
Looking for a RPM level 7 4L60 trans justintime1223 C5 Parts for Sale/Wanted 0 05-28-2013 02:23 PM
01 Auto Trans 1-waterman-1 C5 Tech 0 09-08-2012 12:00 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
