who makes best c5 single turbo kit?
My buddy is more then willing to build more kits. I'll just let him use my car to build it. At least over the winter. Cause I drive my car when its nice. I can give his info if anyone wants to talk to him . pm me
They do make a decent kit.
But everytime I called and had a question no one would know the answer for some reason, should of thrown a red flag up but I learned a lesson the hard way.
Whatever you do if you do decide to go rear mount, DO NOT run that BS Tilton pump they had on their red car or the silver mile car that wrecked. That design doesn't work and even a brand new pump won't do what you need it to do to move oil to feed the turbo or back to the pan. Turbowerx Exa Pump will solve all of your oiling issues, let your motor feed the turbo and use the Exa Pump to return it to your pan problem solved.
I have a rear mount 91mm on my car and it has no issues spooling, so not sure what overkill means. A well built motor and good planning will take all the spool questions/worrries out of the equation.
Another vote for DANZGLASS'S buddy.
DanZglass and his fabricator buddy, single rear mount kit.....looking at his thread, and i if wanted to do again, he will be the first one i would contact. great job DanZglass i do great welding but not near what your friend did on your kit...impressive welding and fab work.
