Another UPP Turbo car with some extras on the road
Drivers side contacts are clean. Since I added the ECS fuel adapter ring idk if the float is getting held in a weird spot or can't function as designed because of the extra corrugated fuel line in there. I just shortened the hose from the pump to bulkhead to alleviate unnecessary space usage. I'll put it back together and see what it does with 16 gallons.
Well I got home and my new VIS hood was here, undamaged and looking good............. Until I looked at the underside. So I'm thinking i should've bought the Sunoco C5 hood, but I can trim and reinforce the hood to make it work.
I think I might look good if just the intake top sticks through on the stock hood, and have it painted the same as hood.
I can't remember the members name with the Blower + Pro-Flo combo, but he cut the stock hood and had a badass looking setup.
What all did you have to do to get the PROFLO to fit? I dont mind cutting my cowl, but I have heard you need to lower the motor a bit? Could you PM me any details please? Thanks!
Everyone loves updates, at least on the daytime talk shows anyway.
Street tuning and breaking the clutch in currently with the lovely +/-28 degree weather. The setup has 94 miles at the moment and waiting for the 500 mark to start beating the **** outta the car. Boost rolls in nice going off the 8lb waste-gates only. I can see 3lbs by 2400 in 5th and 4th gear is pretty much the same, easy on the throttle. No bad noises, waste-gates and bov aren't annoying, kinda liking driving the car again. New hood is cut but needs to be reinforced and I have to oval the fender holes to pull them in and close the damn hood gap at the A-pillars Oh my fuel gauge issue was a broken board for the float contact path.
#33
I can't help it bro. I'm addicted. You know where I work lol. it's like a crack ADDICT,..woring in a CRACK FACTORY..... I can't say no!
(starts itching)
lol. BTW it's 79degres here right now.
Try some HEAT(torch-not to cut though) on the broken *** o2. Then grab some marshmallow.s
#35
(starts itching)
(starts itching)
I did get some more miles today before the work calls started pouring in.
#36
Damn senspr was almost welded in there. Heat didn't work, penetrating oil didn't help, I had to weld the box end of a wrench on the damn thing to break it loose. Then the exhaust manifold had to come off for a broken stud. The e-force on this thing is pretty damn fun for an otherwise stock car
I haven't driven a vehicle with one yet, they seem like pretty sweet all around units. I bet it's a blast to drive.
#37
Might as well update. Car is getting the snot knocked out of it road testing. Fuel system is more than adequate only hitting high 60's% duty cycle on these FIC 96lb/hr injectors at 48# base pressure. I do need to replace the eboost street boost solenoid as it quit the other day running 12#'s boost currently. Or I might convert to the dual control solenoid method to achieve my 18-20lb desired boost level. I will say the power is so smooth with this setup compared to the old stroker and nitrous setup. I'm truly happy with this car again.
#39
Since I've had time to fix everything else while I was at it. I rewired the stereo and made a new amp plate anchor bolted it to the frame. As well as a new tire/gas jug carrier because I sold the pull behind trailer.
Tirerack before trimming down, heat shield for gas can, and paint
New hatch rework
New hatch rework
