Custom FMIC and Vertical Radiator Results and Pics
Hey Guys,
I've been lazy getting this thread started, but I figured y'all would be interested in this setup that the guys at JTM Motorsports fabbed up for me. Needless to say, it's much more beautiful and daily driver friendly than the previous setup (procharger dual IC ground clearance w/ lowered cradle=). It also dropped water temps by about 10, although I still need to put my new oil cooler on.
The engine is a forged ls3 block (thanks Aaron @ Texas Speed) with an A&A D1sc bracket and some other goodies. I owe a lot of thanks to Josh @ A&A for going above and beyond- as well as countless other forum members and sponsors whose write ups and experience helped a ton over the course of the build.
Anyways, here are the pics of the custom FMIC & radiator. The real thing of beauty is the chromoly cradle John and Matt @ JTM dreamed up and fabbed up, which gives me ground clearance I never knew was possible even when stock. It even retains the factory A/C condenser, which is only apparent in the first couple of pics. All that new found space up front is just begging for a turbo. some day...
BTW, this whole build was just supposed to be a weekend cam swap about 1 year ago until I pulled the stock cam and found the lobes chewed up thanks to some quality ls1 lifter trays I presume So I dropped in a forged ls3 and an RPM level 6.5 4l60 along with everything else that goes along with that sort of thing, since that was the only reasonable thing to do. Then I got some AFR 225 heads from a forum member that I couldn't bring myself to mill down a bunch to an N/A compression ratio, so I threw the d1 procharger kit I got from a local forum member on there.
Then the flat bed tow truck who gave me a lift over to JTM for the start up tune managed to hook the factory radiator cradle, so the only reasonable thing to do was have them make this custom setup haha.
Here it is as it sits today. I'm trying to get to Atco this weekend to see what it runs. I'm sure I left out a bunch of info since I'm writing this at 2am, so let me know if you have any questions.
That is super slick - too bad they don't sell these!
Thanks,Matt
Thanks,Matt
What are the dimensions of the new rad? Looks REALLY thick.
Someone really needs to sell these as a bolt on cooling solution. If they came with a new cradle and front crash beam it could almost be a bolt on solution!
Also whats the size of the inter-cooler?
Received 1,762 Likes
I agree It's a Griffin 26x16x3 radiator and there's enough room b/t the rails for a 28" wide rad looking at it. Intercooler is a CXRacing 24x12x4. It's definitely doing some favors for the D1sc with a huge 4.75" pulley to make the 8-9# being pushed through it w/ an air filter.
I don't remember how the IAT's were, and I didn't have a data logger for my runs at Atco last night. I have a cheap scanner that I can go out and have a buddy check with on the street.
Matt, It's been a couple years since I've been to the drag strip, and my first time with 575rwhp so my skill was definitely the limiting factor. After some ugly passes, I finally got a 10.75 before the track closed, but I know I can do better.
John
