High altitude guys how much boost will a 3.47 on a d1sc net me?
Well having a hard time with this getting different answers. Procharger says 12psi-17psi. The numbers changed the more we talked and after I got off the phone I'm still not sure. I dont want the motor to go pop on the dyno..I could use your help thanks
5600 ft above sea level
8k da usually
only 91 octane
no meth(for now)
3.47" pulley
I am looking for mid to high 500's to the wheel..Which I believe is safe
2001 ls1
d1sc on A&A bracket
4" Dongle(suppose to restric some boost?)
fmic
1 7/8" headers
91 pump
ported tb
6 rib
stock size balancer
stock maf
stock long block 93k or so..
320lph pump
casper fuel harness
8k da usually
only 91 octane
no meth(for now)
3.47" pulley
2001 ls1
d1sc on A&A bracket
fmic
1 7/8" headers
91 pump
ported tb
6 rib
stock size balancer
stock maf
320lph pump
casper fuel harness
you should see 500hp with only 8-10psi
as for what you'll actually make, i ain't got a clue with a belt-turbo. my 2300 went from 11psi in Houston (65') to 9.5psi in Rapid City (3800')
So we are at high altitude and he is wondering what kinda of boost you guys are seeing with this pulley. Like to get some info from people at the higher elevations with prochargers about pulley sizes and procharger doesn't seem to have the answer he's looking for.
Here in Colorado at just about the same conditions as yourself, most people see about 2 to 3 less pounds of boost compared to the same setup near sea level.
But what size pulleys are you guys using. Again what will I boost though? I don't wanna be on a dyno going boom or trying to change a pulley and go get a belt. We went from 8psi to 22 psi. Lol that's a huge range
the boost reference i gave from my roots blower was to show you what a 2500' change did on my car
Is that what you have on that Lighting? You have to remember this d1sc flows some air1400cfm from what my man Tcruse just sent. You have stock roots I believe?? What do those flow?I'm gonna pulley up with a 4.5 and go from there. rather be safe then sorry.
