2 bar map issues
2 bar map issues
I'm doing some street tuning on my car right now and I just converted the car to a 2 bar SD tune.
When I make a WOT pull, my map sensor pegs at 105 at 2600rpm and doesn't go up anymore. But it also doesn't drop. What is going on?
402 ETP 240 heads YSi 3.125" pulley.
What year model is your car? My 1998 would not auto scale for the new 2Bar MAP. I had to go into the HPTuners histograms and find those built for the 1998.
In the scanner table, make sure you don't have Manifold Absolute Pressure (SAE) PID. Once you've scanned the vehicle (assuming you've properly installed the 2 bar OS), the 2 bar MAP PID will present itself under engine\airflow\....
You may have to clear the previously scanned vehicle to get the 2 bar to kick in, for whatever reason.
Right click in the chart, expand the section your MAP is in and increase the range to 200kPa.
Make sure you have a 2-bar MAP in your table and if you don't, right click, delete the one you have and then right click>insert>airflow Manifold Pressure 2-bar
