New build. 5.3 rear mount c5z06
Old 09-01-2013, 02:50 PM
DANZGLASS
DANZGLASS's Avatar
Default New build. 5.3 rear mount c5z06
Motor:
5.3 L33
stock bottom end
LS6 cam
799 heads
ls1 intake/tb
ls9 head gaskets
arp headstuds
ls7 lifters
dual gold springs
Turbo:
precision billet 7175 .81 ar
treadstone 1300hp vette style intercooler
tail wastegate
tail bov
aem wideband
boost gauge
2.5 bar map
MM boost catch can
aem meth kit/klotz race fuel concentrate/92oct
3inch stainless hot side wrapped
3in cold side aluminum.
Vibrant VanJen v band Clamps
c5z exhaust manifolds
Upp fuel kit
80lb injectors
turbowerx exa return pump.
drivetrain will be stock m12/ stock 3.15 3 rib for right now. street use only.
Motor goes in this week, fabbing starts right after.
Old 09-01-2013, 02:55 PM
Chris Stewart
Chris Stewart's Avatar
this sounds awesome!
Old 09-01-2013, 03:38 PM
LSOHOLIC
LSOHOLIC's Avatar
Cool build.......how many lbs of air is that wheel rated at ??
Old 09-01-2013, 03:50 PM
DANZGLASS
DANZGLASS's Avatar
i dont know the rating on this turbo. i know its done over 1k whp on a 3.4 stroker supra. looking to be in the 700whp range think its got enough air for that. trying to spool as fast as possible and not choke up top.
Old 09-01-2013, 04:27 PM
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Support Corvetteforum!
MVP'S ZO6's Avatar
Sounds like its going to be a real monster!!
Old 09-04-2013, 08:37 PM
_zebra
_zebra's Avatar
so you swapped to auto gears in your 3-rib? that should help initial spooling
Old 09-09-2013, 11:58 PM
DANZGLASS
DANZGLASS's Avatar
We decided we are going to go with a divided housing with a .96 ar. We are also going to run a quick spool valve. Might as well get the most out of it. Car is on the rack and underway. Will be posting pics as we go.
Old 09-11-2013, 11:01 PM
turbo-civic-si
turbo-civic-si's Avatar
Old 09-21-2013, 06:09 PM
DANZGLASS
DANZGLASS's Avatar
And it begins!
Old 09-21-2013, 06:12 PM
Blitzkrieg
AKA "The CLOWN"
Blitzkrieg's Avatar
Old 09-21-2013, 06:13 PM
Shoaf85
Shoaf85's Avatar
Good call on upgrading turbine. I was gonna recommend a bigger unit after reading the .81 ar in the first post.
Subscribed...
Old 09-21-2013, 06:19 PM
DANZGLASS
DANZGLASS's Avatar
turns out they dont make a divided housing for this turbo so the quick spool valve is out for now. We are sticking with the .81 unless it stops us from making 650+
Old 09-21-2013, 07:21 PM
Shoaf85
Shoaf85's Avatar
If 650 is all you're shooting for then you MAY be fine. It may just hurt it some up top!
Old 09-21-2013, 07:40 PM
DANZGLASS
DANZGLASS's Avatar
hoping for 700whp actually. But i can swap if it needs a bit more to get there.
Old 09-21-2013, 10:31 PM
Shoaf85
Shoaf85's Avatar
Good deal. Gonna be a blast regardless.
Old 09-22-2013, 03:40 AM
a/c man
a/c man's Avatar
why are you using a 5.3 if you want 700hp the stock ls1 or ls6 will work unless you toasted your stock ls1 already?
Old 09-22-2013, 10:55 AM
DANZGLASS
DANZGLASS's Avatar
I had a 403 with a 150 shot actually. Made 535 NA. Had a ls7 small bore top end. 6 k on that motor and two hits of the nitrous. Intake valve head broke off and took out bout everything. I decided I'm done spending 10k+ on motors so I went this route.
To New build. 5.3 rear mount c5z06
Old 09-22-2013, 10:57 AM
DANZGLASS
DANZGLASS's Avatar
Pretty sure the shop I was using did ****** valves REV probably. Which failed in no time.
Old 09-22-2013, 11:24 AM
SBCGENII
SBCGENII's Avatar
Ls7 small bores on a 403? Who's heads, RPM?
Old 09-22-2013, 11:33 AM
DANZGLASS
DANZGLASS's Avatar
I won't name names due to the rules.
Quick Reply: New build. 5.3 rear mount c5z06
