New build. 5.3 rear mount c5z06
07-08-2015, 05:40 AM
Just curious on where you're at with this build?
Any chance your friend has an idea on roughly how much he'd charge for piping only? Cold and hot side.
07-08-2015, 11:55 PM
its kind of tuff to do the piping without the car there. I suppose he could potentially make piping using my car. Cars basically done again. Had some issues with the new motor and lost interest for a while.
07-11-2015, 06:12 AM
Back pressure
Quote:
Originally Posted by
DANZGLASS
How much backpressure you have?
07-11-2015, 10:38 AM
06-10-2016, 09:27 PM
did a new fuel system from scratch. upp kit took a **** and was having issues. should be able to finally finish this thing!!!
06-10-2016, 09:29 PM
DANZGLASS
did a new fuel system from scratch. upp kit took a **** and was having issues. should be able to finally finish this this!!!!
Details on the custom fuel system? I'm still going back and forth about what to do with mine.
06-12-2016, 07:05 PM
looking forward to seeing what's next!
06-19-2016, 04:06 PM
just did bigger lines, better rails with two in two out, external 044 with internal 255.
06-19-2016, 04:15 PM
DANZGLASS
044 on a hobbs or full time?
06-19-2016, 04:19 PM
06-19-2016, 04:20 PM
Echo97vette
hobbs. upp was a garbage setup. THis is a real return style this time. used a bulkhead fitting in the bottom of the tank.
06-19-2016, 04:24 PM
I can go over it in detail in a pm if you want.
02-06-2017, 08:05 AM
i was doing some research on rear mount setup. I see all the pics up front of the build are now gone. Did you post them somewhere else and the link got broken?
02-06-2017, 09:34 AM
Im guessing something happened to them then. I didnt do anything.
02-06-2017, 09:35 AM
I just checked and i still can see the pics on the front page. Weird.
02-06-2017, 09:44 AM
02-06-2017, 10:49 AM
posts 31*33 are broken... the list up top looks like all of it.
04-23-2017, 09:33 PM
04-24-2017, 02:19 AM
whoa! yeller just wasn't doing it fer ya no more?
04-24-2017, 08:09 PM
_zebra
needed a repaint anyway. So since yellow was so expensive i went white.
