2bar map plug and play? (MAF tune)
Hey,
I mentioned to my buddy that I have one of those ODBII code readers which connects to my Iphone. I have an app that can also show live dashboards like IAT's, etc.
The question came up, would the stock OS/Sensor read boost properly where it would be reflected on this software. The main intention would be to do simple logging to see if i am having belt slip or seeing higher IAT's, etc.
So - If I were to just get a 2 or 3 bar map and plug it into the stock cable, do you think the stock OS would read the boost readings from the MAP sensor (I'm running 12psi)?
Assuming the answer to the above is 'sure', as I am a MAF tune, would there be any negative impact to my MAF tune by swapping the MAP sensor out? I'm not a tuner, so not sure what the MAP would be used for in a traditional MAF tune.
Thanks!
John
Thanks!
John
Now, this is all fine. Without somebody asking questions, this forum would be dead.
So for this to work properly, assuming you have HP Tuners capability, you would have to give the car an enhanced OS as in 2 Bar speed density. GEN III PCM's only allow for speed density once the enhanced OS has been applied. (***No MAF tuning once the 2 BAR MAP-Speed Density has been applied***) You would then install the 2 bar map sensor and input the correct offset and voltage for that particular sensor so the computer reads it accurately. Then you should be able to read the amount of KPA or manifold pressure you have via phone.
The easier, more basic thing to accomplish the same task, would just be to introduce a boost gauge into the vacuum port on the intake. That will also tell you how much boost you're making and would be much cheaper and more beginner friendly.
Appreciate the responses - I suspected this was a bit more than just plugging in a larger resolution sensor and going
I do have a manual boost gauge in the car already. I try to keep an eye on it, but things are moving so fast it's hard to keep track of everything. Having this was more of a nice to have around seeing boost curve to see if any slipping, etc.
I have quite an older setup that I've modified/tweaked over the years. Havent taken the plunge on a direct drive and was trying to find evidence to justify it.
what application are you using to display the data?
like to see what gauges look like on like an ipad or something like that rather than going with traditional gau
ges on an old restomod
