Can it fit in the rear compartment?
I swore i've seen you guys post pics of your 10lb. bottle in the rear compartment. A friend of mine told me that it wouldn't fit. Maybe it'll fit without the top over it?
I finally got my NX kit, can't wait.
Frank
Frank
Re: Can it fit in the rear compartment? (NYtoCA)
10lb Bottle and top fit perfect in rear compartment :cheers:
[Modified by jetskifast, 10:18 PM 6/28/2002]
Re: Can it fit in the rear compartment? (jetskifast)
That is a clean install ...
Re: Can it fit in the rear compartment? (NewVetteLover)
NeweVetteLover
I researched my N20 install for a month, before install.
I also mounted solenoids away from motor heat. Used stock air intake box mounting bolts, to mount solenoid brackets.
NeweVetteLover
