WARNING if using Proform LS valve covers!
Old 08-04-2013, 03:17 PM
JDS99
Support Corvetteforum!
JDS99's Avatar
Default WARNING if using Proform LS valve covers!
I recently had the baffles off to install a couple -10AN fittings to mine for crankcase ventilation. The covers have a 3/8" hose connection already on them from Proform. So you would assume it's the same on the inside under the baffle, right?.... WRONG.
It's smaller than 1/8" pinhole on the inside. If you're running these covers and using the vent tubes, or plan to, then I strongly recommend you make some changes before you start pushing seals out.
Old 08-04-2013, 07:52 PM
4DRUSH
4DRUSH's Avatar
Never heard of them, what do they look like from outside.
Old 08-04-2013, 08:12 PM
JDS99
JDS99's Avatar
http://www.proformparts.com/category...S_Valve_Covers
Old 08-04-2013, 08:24 PM
4DRUSH
4DRUSH's Avatar
Not bad looking
Do they leak?
You using the coil brackets?
Old 08-04-2013, 08:57 PM
JDS99
JDS99's Avatar
Not bad looking
Do they leak?
There are a few indirect photos of them on mine in here:
http://forums.corvetteforum.com/c5-f...5-lives-3.html
No leaks so far. They have a rubber washer to seal to the bolts.
I didn't use the coil brackets. Mounted the coils in the fenders instead.
Old 08-05-2013, 12:31 PM
5 Liter Eater
5 Liter Eater's Avatar
St. Jude Donor '11
I run those. Thanks for the tip. I run the drivers side nipple with 3/8 hose to atmosphere but I also have a breather on the oil fill hole with a 5/8 hose. Both run to the back of the car.
I do like these covers.
Old 08-05-2013, 12:38 PM
MVP'S ZO6
ISIS SUCKS FAT CHOAD
MVP'S ZO6's Avatar
They look like nice covers. Easy fix for the 3/8 nipple to the pin hole size under the cover. Definitely glad you pointed it out for other who may not pay attention. How much are the covers?
Old 08-05-2013, 12:44 PM
5 Liter Eater
St. Jude Donor '11
I want to say mine were ~$425 with the coil brackets. They're similar look and quality to Katechs which are ~$400 but their coil brackets are another ~$200.
Old 08-05-2013, 07:25 PM
JDS99
JDS99's Avatar
Don't forget they also clear the alternator without modification, unlike the Katechs!
Old 08-05-2013, 09:43 PM
madmatt9471
madmatt9471's Avatar
Location: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Stock ones are the same way too! You need to have them hogged out if installing a AN fitting on the covers!
Thanks,Matt
Old 08-05-2013, 09:49 PM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
Thanks,Matt
When I did my stockers I couldnt believe the small hole.. Robert
Old 08-29-2013, 01:28 PM
ProformParts
3rd Gear
ProformParts's Avatar
Regarding the PROFORM LS valve covers...only the driver side cover (PCV) has the swaged tip. The passenger side tube is wide open. Lots of internal clearance inside for big rocker setups.
Old 08-29-2013, 01:47 PM
5 Liter Eater
St. Jude Donor '11
Ah, even better info.
Yea I got them to clear my Jesel J2k's and I'm very happy with them.
Old 08-29-2013, 02:11 PM
ProformParts
3rd Gear
Please post a couple pictures if you can, I'd love to see how they look on your engine.
Old 08-29-2013, 04:00 PM
LedfootLarry
LedfootLarry's Avatar
Here is a pic for ya
Old 08-29-2013, 07:38 PM
ajrothm
ajrothm's Avatar
Received 1,095 Likes on 746 Posts
Great looking valve covers....but the ventilation efforts from them are pitiful...
Good thing you checked em Jon.
Old 09-04-2013, 11:07 AM
5 Liter Eater
St. Jude Donor '11
Not as clean as Larry's but here are mine:
To WARNING if using Proform LS valve covers!
Old 09-04-2013, 12:01 PM
regorih
regorih's Avatar
looks pimp
Old 09-25-2013, 12:56 AM
5 Liter Eater
St. Jude Donor '11
Drilled my passenger side vent out today.
Old 09-25-2013, 12:04 PM
JDS99
JDS99's Avatar
Nice! Your engine says thank you I cleaned and used a little loctite on the screws when I put the baffle back in. I don't think they had any from Proform, and made me nervous.
How's the new engine and 62/65's doing?
Quick Reply: WARNING if using Proform LS valve covers!
