Nitrous, someone with knowledge help
A friend has a nitrous kit he used on his lt1 z28 and was selling it to me dirt cheap, so wanted to know what i should know about nitrous? He said it can be used wet or dry has nozzles for a 75 shot up to 150, can be activated my the gas pedal or buttonbuttonand not sure what components i should buy for safety and not blow my motor?
I would buy some sort of controller for it. There are controllers that will do window switches (activate in certain rpm ranges only), wide open throttle and many other features. These 2 are pretty basic imo. Another one people like is if the car goes lean it will turn off the kit. With a controller all you have to do is turn it on. The controller will do the rest.
