Which Magnacharger do I have?
Old 06-30-2013, 01:21 AM
9c1ny
9c1ny's Avatar
Default Which Magnacharger do I have?
Uploaded with ImageShack.us
I am guessing its a MP112 but there is no model # on any of the paper work I got with the car and none of the serial numbers seem to bring up anything on search. To add further confusion it has nothing on the unit itself except for "CARB D-488-6" LS-1/LS-6"
Unit was installed in 2008
can anyone point me in the right direction to pick up some spare belts for it??
No problems with it (knock on wood) but I would like to have some on hand if one breaks
Thanks!
Old 06-30-2013, 12:46 PM
9c1ny
9c1ny's Avatar
ttt.........
Old 06-30-2013, 01:01 PM
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Support Corvetteforum!
MVP'S ZO6's Avatar
If you don't find anything you can remove the belt and measure it. Take into account belt stretch.
Old 06-30-2013, 01:13 PM
pewter99
pewter99's Avatar
Received 1,194 Likes on 704 Posts
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
looks like the painted version of the 112....and it looks like its on a C5 so I am going with 112...looks like it has been serviced...
Old 06-30-2013, 01:26 PM
NITRO UK
NITRO UK's Avatar
OP hi
See if the numbers on the belts are readable, then maybe NAPA ,AUTOZONE. or magnuson.com
Can get you the numbers on both belts if you need em , and I assume you have a 3.50 front pulley, should be on the front just near the locking nut.
Old 06-30-2013, 01:56 PM
9c1ny
9c1ny's Avatar
thats what I am guessing, it IS on a C5 Z, I have the warranty card for it from the previous owner, I think I will try to contact the company with all the info and verify, I would think they would stamp the model right on them
9c1ny
9c1ny's Avatar
Originally Posted by NITRO UK
OP hi
I'll take a look later, thanks for the heads up
Old 07-01-2013, 01:05 PM
9c1ny
9c1ny's Avatar
Magnacharger says MP112 5th Generation for anyone curious
Old 07-01-2013, 02:21 PM
meadowz06
meadowz06's Avatar
St. Jude Donor '09 and '13
Just like mine-MP112.
Old 07-02-2013, 07:45 PM
BLOWNBLUEZ06
BLOWNBLUEZ06's Avatar
If you were lucky, it would be a MP122 or even a MP112H or MP122H. The H designation was for the high helix rotors, which added 10° to the existing 60° rotor design.
That rear belt isn't something listed by Gates in their catalog (or at least it wasn't last time I pursued getting one). Either Magnacharger, Callaway and maybe Lingenfelter can supply the rear belt for you. If they offer a HD belt, get it! If not, the regular will have to do. Set the tension on it, drive it 100-200 miles and re-set the tension on it.
Old 07-07-2013, 04:34 AM
_zebra
_zebra's Avatar
the case looks too short to be a 122... but i'm used to my 2300, so it ain't like i look at these all day
To Which Magnacharger do I have?
Quick Reply: Which Magnacharger do I have?
