Boost leak?
Old 06-30-2013, 12:51 AM
EZ2BEVILC5
EZ2BEVILC5's Avatar
Default Boost leak?
Hey,
How do you determine if you have a boost leak? and how do you locate it?
Old 06-30-2013, 06:01 AM
helga203
helga203's Avatar
Originally Posted by EZ2BEVILC5
Hey,
This is what i did. It's caveman but it worked. If you have s/c'er i duct taped the inlet to the blower real good; took the brake booster line with an air hose( i extended the booster line about 4 to 5 feet so i can lay on my back under the engine to hear if there's any leaks) and applied air and i could not believe how many leaks i had. I though i tighten down clamps, you have to crank the sh#t out of them. I had a air nozzle with the rubber tip. It worked good when your by yourself. Turbos are differnent.
Why do you think you have a boost leak????????
Old 06-30-2013, 08:53 AM
EZ2BEVILC5
EZ2BEVILC5's Avatar
Default leak
I'm at high elevation. I had the car tuned in Phoenix and had around
9LBS of boost. When I returned to elevation I could have sworn I was getting around 6-7 LBS. Of course I can't remember 100%, but know I am only seeing 5LBS. I noticed because it didn't seem quite as fast.
Any thoughts?
Old 06-30-2013, 08:59 AM
helga203
helga203's Avatar
Any thoughts?
yes check for leaks, belt slip??
Old 06-30-2013, 09:00 AM
EZ2BEVILC5
EZ2BEVILC5's Avatar
Thanks I will try what you posted sound good!!!
Old 06-30-2013, 09:43 AM
helga203
helga203's Avatar
Old 06-30-2013, 10:13 AM
EZ2BEVILC5
EZ2BEVILC5's Avatar
Default Belt
I guess I will tighten the tensioner to be sure. I don't hear any noise. How would you know?
Old 06-30-2013, 10:36 AM
helga203
helga203's Avatar
leak u will hear. belt just make sure it's tight as hell. Lease amout of deflection in belt.
To Boost leak?
Quick Reply: Boost leak?
