Electric Water Pump w/ A&A Bracket
Old 06-04-2013, 12:21 PM
Chrisrokc
Chrisrokc's Avatar
Default Electric Water Pump w/ A&A Bracket
Thinking about buying an EWP to fight the summer heat. Do all A&A brackets (even the newer style ones) require modification for a 55gpm EWP to fit?
Old 06-04-2013, 02:31 PM
c5austin
c5austin's Avatar
Yes, nothing a dremel can't take care of though.
Old 06-04-2013, 04:26 PM
Chrisrokc
Chrisrokc's Avatar
Anyone have pics of this?
Old 06-04-2013, 07:14 PM
Mike04
Mike04's Avatar
I read somewhere on the forum the newest bracket they make works without modification.
Here is a link to one I sold that was modified. You can see form the pics.
http://forums.corvetteforum.com/c5-p...r-bracket.html
Old 06-04-2013, 09:10 PM
madmatt9471
Support Corvetteforum!
madmatt9471's Avatar
Location: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Mine did - and I think A&A will let you know that if you should call -
It's a bummer because it sure slows down progress!
Thanks,Matt
Old 06-06-2013, 01:11 PM
kromberg
kromberg's Avatar
I had to have one standoff be adjusted when I switched to an electric pump.
Old 06-11-2013, 01:08 AM
RMS-MAN
RMS-MAN's Avatar
The latest version of the C5 A&A bracket clears the Meziere EWP without modification needed.
The C6 bracket will not fit a Meziere EWP, only the C5 bracket.
Old 06-11-2013, 01:42 PM
joshtownsend
joshtownsend's Avatar
Thats not exactly correct. I think they changed up it after the latest one came out. My bracket didn't clear and its the latest, but i bought it 1.5 years ago or so. I circled where i had to grind down on it some..you could also grind on the water pump.
Old 06-11-2013, 05:46 PM
BLOWNBLUEZ06
BLOWNBLUEZ06's Avatar
I'm curious about that because it appears that what you circled is on the opposite side and opposite end of the bracket from the WP.
Old 06-11-2013, 07:06 PM
Josh@AandASuperchargers
Platinum Supporting Vendor
Josh@AandASuperchargers's Avatar
Is this near where the thermostat housing sticks out?
Old 06-11-2013, 09:47 PM
joshtownsend
it was by the housing, but not on it..it was hitting on the pump housing itself. lie i said, it was 1.5 years ago..if not a little long.. i cant really remember.. but it didn't just fit right on... but I took off the EW anyways.. mechanical one works much better and flows more when i need it...Ill look tomorrow, i have the pump sitting on a shelf and a spare bracket as well.. things are still crazy around here..
To Electric Water Pump w/ A&A Bracket
Quick Reply: Electric Water Pump w/ A&A Bracket
