New LS Timing Cover Alignment Tool! Check it out!
Old 05-12-2013, 07:01 PM
SacCityCorvette
Supporting Vendor
SacCityCorvette's Avatar
Location: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Default New LS Timing Cover Alignment Tool! Check it out!
AlignIt Timing Cover/Crank Seal Alignment tool
Here is a simple but very effective tool to help you make easy work of installing your LS1-2-3-6-7-9 timing cover and seal.
The Alignit tool gets the timing cover centered perfectly with the crank and installs the seal in seconds!
Having the seal centered accurately with the crank minimizes the chance of seal leakage. Only $19.95
http://www.saccitycorvette.com/Timin...nmenttool.html
Update! We made a improvement to the AlignIt!
We will have to add a a few bucks to the cost. The New price
will be $26.95.
We will keep the $19.95 price through the Memorial weekend.
After that we will implement the new price.
Also if you purchased a AlignIt without the O-Ring and you would like a O-Ring installed at no charge just send it back to us.
Basically the O-Ring lets the AlignIt fit snugger in the cover holding it in place better.
One other thing, we are working on a Rear Main AlignIt tool.
Here is a video that shows how simple it is to use.
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old 05-14-2013, 01:52 PM
SacCityCorvette
Supporting Vendor
Inexpensive way to insure proper alignment of your LS timing cover. Also makes seal installation a breeze!
Old 05-14-2013, 04:42 PM
4DRUSH
4DRUSH's Avatar
Now that is a nice product I must say, I think I'll buy one.
Old 05-14-2013, 04:47 PM
4DRUSH
4DRUSH's Avatar
Although, I don't see it on your website. Link ?
Old 05-14-2013, 05:04 PM
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Support Corvetteforum!
MVP'S ZO6's Avatar
Cool product gents!!
Old 05-14-2013, 05:42 PM
SacCityCorvette
Supporting Vendor
Sorry, just added a link. And it on our website under LS1-2-3-6-7-9
Old 05-17-2013, 02:19 PM
Y2KRoadster
Y2KRoadster's Avatar
Do you neeed to put anything on the seal or the timing cover before installing? RTV, white sealer tape, etc? Thanks.
Old 05-17-2013, 02:33 PM
Neil B
Neil B's Avatar
Does it work with both stock and aftermarket crank snouts?
Old 05-17-2013, 02:39 PM
SacCityCorvette
Supporting Vendor
Hi Y2KRoadster,
A little RTV in the corners where the timing cover and pan meet.
I don't think you need anything on the seal.
You should double check that.
Christian
Old 05-17-2013, 02:41 PM
SacCityCorvette
Supporting Vendor
Hi Neil,
Yes, I believe they are the same size.
Christian
Old 05-17-2013, 03:22 PM
Neil B
Neil B's Avatar
Originally Posted by SacCityCorvette
Hi Neil,
Christian
The GM Kent-Moore tool won't work with keyed aftermarket cranks, but it looks like your tool has the required keyways.
Old 05-17-2013, 07:18 PM
SacCityCorvette
Supporting Vendor
Yes it does. We got input from forum members and they recommended a keyway groove so we did it.
Christian
Old 05-20-2013, 06:33 PM
SacCityCorvette
Supporting Vendor
We have them in stock!
Old 05-21-2013, 02:36 PM
SacCityCorvette
Supporting Vendor
Cool Tool!
Old 05-21-2013, 08:15 PM
sami85L98
sami85L98's Avatar
Nothing on seal however RTV on both sides of timing cover at bottom corners, not too much, and torque bottom 2 bolts first and go upstairs in cross pattern.....very important.
Old 05-21-2013, 10:01 PM
4DRUSH
4DRUSH's Avatar
Mine came a couple days ago, very happy with it.
Old 05-21-2013, 10:32 PM
Y2KRoadster
How about a tool for installing a rear main seal? If you have one of those, I'll buy both!
To New LS Timing Cover Alignment Tool! Check it out!
Old 05-21-2013, 11:15 PM
gotjuice?
gotjuice?'s Avatar
St. Jude Donor '13
I am in for both.
Old 05-25-2013, 02:58 PM
NITRO UK
NITRO UK's Avatar
Want to do a forged motor soon as,that tool can only help,even if i only use it a few times.
Simple,and brilliant.
Any chance you could ship to a limey in the uk ? USPS works well
Cheers Nitro
Old 05-25-2013, 07:57 PM
SacCityCorvette
Supporting Vendor
Cheers Nitro
Hi NITRO UK,
Sure, go ahead and order and we will get it out to you.We will let you know if there is additional shipping charges.
We are always trying to improve our products and we have made a improvement that will add about $7 to the cost. If you order now before our website is updated you can still get it for $19.95 I will post a updated picture.
Thank you,
Christian
Quick Reply: New LS Timing Cover Alignment Tool! Check it out!
