Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Forced Induction/Nitrous
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection, Meth Sponsored by
A&A Superchargers
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-10-2013, 05:46 AM   #1
Steve@C56
CF Senior Member
Default v3Si, MN6, 11.133@128.56 on airfeild now... AIR FILTER or not the next race ?
Hi everybody
I hit 11.133 the past weekend with A LOT issue (clutch who was smelling at the first run, often not able to put in 2th or 3th gear, rpm limit on the last 100 ft @ 7400 on 3th gear because affraid to not be able to shift in 4th, leak on header - collector alluminum seal open on cylender 1 -... battery, computer, car who was telling me sometime "REDUCE POWER ENGINE" when losting oil pressure and fuel tank gauge, command on driver door who are not usable...)
Have just install my spec 3+ and i'm break-in it for again 450 miles (50 yesterday)
Hope to do a 10.x pass next race (just in 8 days) !
Now, have the regular intake system : A&A air filter, 2.5in(i think) tube from air filter to SC, 2.5in(i think) tube from IC to TB
As some CF member swap from this to 3in pipe and win a lot (have read 2psi/50hp), can i test to ran WITHOUT ANY air filter ?
Or perhaps again better, without any tube before SC ? (and just put a metal grid for to be sure to not having something too hard who enter in the SC)
Evidently, just for the race on strip...
So, what the better choice for hit my best time EVER next race ?
1 : Dont change anything
2 : Without airfilter
3 : Without airfilter but with metal grid (like the one in TB if i find)
4 : Without tube before the SC
5 : Without tube before the SC but with metal grid
Thanks for all who help me ;-)
Steve@C56 is offline   Reply With Quote
Old 05-10-2013, 08:13 AM   #2
4DRUSH
CF Senior Member
4DRUSH's Avatar
Nothing in front of the supercharger
Change clutch fluid
new gasket for headers
Pull codes on DIC for your Reduced Power problems
Add 5 gallons 100 unleaded fuel in your tank
Don't rev to 7400 on stock motor, shift or lift
Take weight out of the car (pass seat, etc)
4DRUSH is offline   Reply With Quote
Old 05-10-2013, 09:17 AM   #3
Steve@C56
CF Senior Member
Quote:
Change clutch fluid
Put codes on DIC for your Reduced Power problems
* Clutch is NEW (break in in process)
* Fluid and slave NEW (DOT 5.1)
* Gasket... impossible to have new for next race cause i'm not in US (have put the old steel stock one)
* Impossible to find 100 (race in Italy), but my E85 in 105 octane ;-) (also, in at 22 at WOT from perhaps 4000 to 6200... i think i dont need to *** some advence)
* 7400, 100% ok with you... i HAD to do that because was at 7000 200ft before 1/4m and rarely able to shift in 4 gear ! I just do that twice (and... had twice 11.1 @ 128mph = 7400rpm/3th/my ET)
* Yes, i will put off passeger seat, my 2 catback, and try to run with 1/8 tank full
* NOTHING in front of SC... i little affaid to have something enter in SC, but, if it's an animal, i will be a steak after the SC
Thanks !
Old 05-10-2013, 09:50 AM   #4
Y2KRoadster
CF Senior Member
Y2KRoadster's Avatar
I would NEVER pull the filter. You realize if something gets sucked in, it will take out your motor and the supercharger. Is that really worth a 10 second skip? Pulley down if you want to go faster, or, get better traction.
Y2KRoadster is online now   Reply With Quote
Old 05-10-2013, 10:15 AM   #5
Steve@C56
CF Senior Member
Quote:
I dont think to HAVE to pull the filter for enter in the 10s, but for min my time, YES (italy "street" record is at 10.600s, a mitsu with something like 847hp on dynosheet)
Dont sure i can hit 10.5xx, but for ONE ou TWO run... may be i can remove air filter
So, better with metal grid like the one in TB ?
Old 05-10-2013, 10:36 AM   #6
4DRUSH
CF Senior Member
4DRUSH's Avatar
Add all that metal grid up & it probably blocks 1/5th of the sc opening, or more
Not sure where you're racing, but around here the tracks are pretty clean, no worries of pebbles bouncing around in front of your car.
Old 05-10-2013, 10:52 AM   #7
Steve@C56
CF Senior Member
1/5 ??? wooaaoohh... i should put off my grid in my stock TB !
It's a airfield who was just be use for drag race 2 times in 2012... Is used rest of the time for little plane... BUT very well prepared (sorry... very well for Italie/Suizerland and France... it's not like in US or Santa Pod in GB)
I have the stock C5 bumper, so, if a part enter in the SC... it's because it's already under the hood... or something who is from dam-air
Other question... Should i close the radiators and IC area ? (put something who is the tube from air filter to SC) for having the most cold air on IC
Or stay it opened for having more colc air in SC ?
(Again, thanks for all of you for this brainstorming )
Old 05-10-2013, 10:53 AM   #8
Robert 2000
CF Senior Member
Robert 2000's Avatar
Thanks !
I wouldn't run that low on gas too risky if it leans out or the gas splashes the wrong way in the tank bye bye engine... I don't beat on mine below 1/4 tan
Robert 2000 is offline   Reply With Quote
Old 05-10-2013, 11:01 AM   #9
Steve@C56
CF Senior Member
Quote:
OHhh, sorry, in my mind, i was thinking to 1/4 !
But, my two first run was close to 17 AFR (argggghhh !!!)
(Because this time, i had only tune my car on road, and just add 20% at PE for the new cam...
And JUST before the last run... Was entering in red area for the fuel (have add 4g immediatly)
LS1 is rock !
So, have use 1/2 tank with 17 runs
What a f... MPG
Old 05-10-2013, 05:31 PM   #10
joshtownsend
CF Senior Member
joshtownsend's Avatar
Yall know big J rolls with 1/16 of a tank and no filter..heck, i wouldn't wear pants if they would let me.. being 5' 2" and 345lb, i need all the help i can get
joshtownsend is offline   Reply With Quote
Old 05-10-2013, 06:34 PM   #11
stevieturbo
CF Senior Member
stevieturbo's Avatar
All this "500 miles" crap is for dodgy drivers IMO. And those same ones would probably just drive 500 miles without hardly even using the clutch and think that's what it needs. A very small amount of sensible break in and slippage when driving is all that's needed.
Ive raced on literally brand new clutches on various different cars and never had a problem.
And unless you can afford to replace the supercharger, I would never consider running it at a race meet without a filter.
stevieturbo is offline   Reply With Quote
Old 05-10-2013, 06:40 PM   #12
ZO6ME
CF Senior Member
ZO6ME's Avatar
Pull the dongle at the s/c and put the filter directly on the s/c. I did this once until I could get the right bend on the new pipe. Felt like more air flow.
ZO6ME is offline   Reply With Quote
Old 05-11-2013, 04:00 AM   #13
Steve@C56
CF Senior Member
Quote:
Wow... i'm a hobbit compare to you (156lb)
Last year, i had put off :
everything possible in the car (fronts carpet also)
passanger seat
catback
and also interior of th doors (including bose loudspeaker)
cannot do better than that
PS : I see/touch the carbon door of a porsche proto... What a f... low weight !!! But, i race agains him, and WIN this weekend, in full weight mode
Old 05-11-2013, 04:07 AM   #14
Steve@C56
CF Senior Member
It's my daily, so, not a real problem to drive 500 miles (have already done 100miles in 2 days, after my work day)
I live behind see and montain, and in a city with +1.000.000 people, so, a lot of stop/start in city, and can change a lot of gear in montain (where i usualy not)
Airfilter... hummmm... have to choice to follow pro or con
Old 05-11-2013, 04:09 AM   #15
Steve@C56
CF Senior Member
Quote:
I think i cannot put the filter on SC, not enouth space for that
Old 05-11-2013, 07:33 PM   #16
Milan
got boost?
Support Corvetteforum!
Milan's Avatar
22 degrees of timing has to be past MBT. Are you pushing water?
Milan is online now   Reply With Quote
Old 05-11-2013, 07:53 PM   #17
Steve@C56
CF Senior Member
Quote:
No water, only E85
22 is exactly that a stock C6 ZR1 GM tune hit at wot
Old 05-11-2013, 09:00 PM   #18
Milan
got boost?
Milan's Avatar
No water, only E85
Apples and oranges my friend. Pull some timing and shift at 7000 instead of 7400. E85 will lose power before you see knock.
Post more details on your setup.
Old 05-12-2013, 02:40 AM   #19
Steve@C56
CF Senior Member
Shift at 7000/7100 was my goal, just have hit 7400 because it was quite impossible to shift in 4th gear
The speedest S-trim on the world use a tune whis 20 from 6000 to 6800 at 1.20g/cyl, with normal fuel and dual nozzle alky, and E85 love&need more degrees
My setup :
A&A V3Si
3.4 pulley
1000cc inj
E85
2" header
Big cam(638 lift, powedband until 6900rpm)/spring/pushrod/retainer
Now Spec 3+ clutch
Old 06-06-2013, 12:21 AM   #20
EZ2BEVILC5
CF Senior Member
EZ2BEVILC5's Avatar
Default Bhp
Hey,
Just wondering, what kind of WHP you are making?
EZ2BEVILC5 is offline   Reply With Quote
Reload this Page v3Si, MN6, 11.133@128.56 on airfeild now... AIR FILTER or not the next race ?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
** Official FI Owners Club ** ProtoVette C5 Forced Induction/Nitrous 405 04-09-2014 06:40 AM
Interesting article on headers - long, but good read Paradigm C5 Tech 14 01-10-2014 06:58 PM
C5 LS1 v3Si 6 speed - no trailer - 11.133@128.56 - on airfeild Steve@C56 Performance Results 0 05-10-2013 04:57 AM
Man - Have any of you guys seen this before?? WICKED C5 Corvette FAQ By Jake Latham! jagzjagz C5 General 10 11-23-2012 11:44 PM
3rd & 4th Race Weekends: Post Upgrade Report darguy Autocrossing & Roadracing 0 10-09-2012 02:47 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
