Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Forced Induction/Nitrous
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection, Meth Sponsored by
A&A Superchargers
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-18-2013, 01:55 AM   #1
Milan
got boost?
Support Corvetteforum!
Milan's Avatar
Default Ysi + 2.75" pulley = lifting heads???
Took Y2Kroadster's car out today to tune it with the 2.75" pulley. First pull we build 20+ lbs of boost, 30 seconds later it's a smoke show (coolant).
Symptoms:
-White smoke
-Coolant in engine bay
-Oil dipstick pushed out (chocolate milk on dip stick)
-Coolant temps shot to 220*
What do you guys think? The car has ARP's and LS9 gaskets. Only thing I can think of is we should have got the heads checked at a machine shop before bolting them back on?
Milan is offline   Reply With Quote
Old 04-18-2013, 01:59 AM   #2
C6 Curtis
CF Senior Member
C6 Curtis's Avatar
S13 Curtis90
Order ARP L19 Head studs and you will probly need new gaskets. Problem fixed.
C6 Curtis is offline   Reply With Quote
Old 04-18-2013, 04:48 AM   #3
breecher_7
CF Senior Member
Quote:
You don't need L19's. HAve the heads checked, get new gaskets, torque them back down properly. Are there any signs of detonation? Are the knock sensors working properly?
breecher_7 is offline   Reply With Quote
Old 04-18-2013, 08:57 AM   #4
4DRUSH
CF Senior Member
4DRUSH's Avatar
Coolant & crankcase are separate systems, sounds like bigger problems than just head gaskets.
4DRUSH is online now   Reply With Quote
Old 04-18-2013, 09:09 AM   #5
helga203
CF Senior Member
Send a message via Yahoo to helga203 Send a message via Skype™ to helga203
Quote:
Oil and coolant jackets in heads cracked????????
helga203 is offline   Reply With Quote
Old 04-18-2013, 09:23 AM   #6
slow ride
CF Senior Member
slow ride's Avatar
Make sure the haed and block are flat and have a excellent finish.
slow ride is offline   Reply With Quote
Old 04-18-2013, 09:46 AM   #7
BLOWNBLUEZ06
BLOWNBLUEZ06's Avatar
L19's are yesterday's news because they are subject to nitrogen embrittlement and don't handle even the slightest of corrosive environments. The new trick if you want the top studs is CA625 material. Even recommended for marine environments.
When head gaskets go, you often push combustion into the cooling system and it spits out from the cap and may leak from the heads.
When you get into the oil, you're looking at a compromise between the crankcase and the cooling. 2 things come to mind. broken piston and or cracked sleeve that runs deep enough into the bore to get under the oil ring and into the crankcase. Broken piston would have to rock it and split the sleeve before the coolant would come into play.
I just lost my motor due to the bore collapsing into the water jacket and it did the same thing you're describing. something GM remedied on their latest LSX blocks by reinforcing the water jackets. They were kind enough to warranty it.
Sleeves will crack along the water jackets where they have way less support. If you digested something in the motor, it will rock the piston and split there too. Either way, I agree with Jay and I'm sorry to say that I'm afraid some serious spending is about to be in order.
__________________
Hsquaredracingengines.com RHS427, custom MAST heads, DP direct drive, and F2, custom fuel system, Moran billet atomizers, Kooks 2", custom BTR cam, RKT56 ZR1 trans, RPM quaife ZR1 diff, DSS shaft, Tilton carbon quad clutch, Haltech Sport 2k. Assembled, installed and tuned by yours truly with the help of Ed Hutchings, Arun
I spend my money on Car Parts and Race Gas... The Rest I waste...
BLOWNBLUEZ06 is offline   Reply With Quote
Old 04-18-2013, 10:23 AM   #8
user_name
CF Senior Member
user_name's Avatar
Send a message via AIM to user_name Send a message via Yahoo to user_name
If you think you lifted them from a little detonation you may be good with some gaskets and milling the heads. I've seen cars push water and then never lift again with some timing pulled out. If it was some other issue existing I agree that it's going to be expensive.
user_name is offline   Reply With Quote
Old 04-18-2013, 11:02 AM   #9
digivex
Wearing Purple
digivex's Avatar
http://www.facebook.com/efiracing
Send a message via AIM to digivex
Quote:
Same symptoms... ignored them for one last race. Result...
Click the image to open in full size.
digivex is offline   Reply With Quote
Old 04-18-2013, 12:05 PM   #10
Milan
got boost?
Milan's Avatar
Car is running 13* of timing and the air fuels were about .72 lambda....no knock on the log.
The only thing that concerns me is that the car kinda sounds like a Subaru to me now which usually means broken ring land. I was kinda hoping it was a result of the head gasket being compromised.
This is definitely some ****** news.
Old 04-18-2013, 12:29 PM   #11
Turbo-Geist
CF Senior Member
Turbo-Geist's Avatar
Any other info on the combination?
Compression ratio, fuel, meth or no meth?
Previous boost level and power numbers?
Have you pulled any spark plugs yet?
Turbo-Geist is offline   Reply With Quote
Old 04-18-2013, 12:54 PM   #12
Y2KRoadster
CF Senior Member
Y2KRoadster's Avatar
Greetings all and thank you for all the info so far. We were able to drive the car back to the house...trip was about 4-5 miles.
Would the car even be drivable if something was trashed in the motor? Yeah...I might be reaching here lol.
Y2KRoadster is offline   Reply With Quote
Old 04-18-2013, 12:59 PM   #13
robert miller
CF Senior Member
robert miller's Avatar
Sounds like one or more bad holes in the block to me..
robert miller is offline   Reply With Quote
Old 04-18-2013, 01:34 PM   #14
Pekka_Perkeles
CF Senior Member
Pekka_Perkeles's Avatar
Quote:
Which plugs?
Stock settings with knock sensors? No desensitizing? Did you listen the engine with knock headphones? Quick transients while driving?
Pekka_Perkeles is offline   Reply With Quote
Old 04-18-2013, 01:45 PM   #15
Milan
got boost?
Milan's Avatar
Quote:
Originally Posted by Pekka_Perkeles View Post
Which plugs?
BR7EF
Stock knock sensor settings, no desensitizing. No we didn't listen with knock headphones this was the first pull after the engine got to operating temp, we didn't even hit 5500 rpm and we eased into it.
Compression ratio is unknown, the motor was built by ETMC but by the previous owner. Alky Control meth kit, M15 and M10 nozzle....IATs were good, like 42* F.
Previous boost level was the same set up with a larger pulley (3.2). If you read the other thread we were trying to figure why the boost was so "low" but we actually figured out our 3" pulley was actually 3.2.
Old 04-18-2013, 01:54 PM   #16
corvette8189
CF Senior Member
corvette8189's Avatar
Send a message via AIM to corvette8189
2.7 pulley ysi with l19 studs held my stock heads on my stock block. They for sale too. They do work. But like others said u got bigger problems.
corvette8189 is offline   Reply With Quote
Old 04-18-2013, 02:42 PM   #17
user_name
CF Senior Member
user_name's Avatar
If that motor was like 11:1 or so you could have encountered some detonation. Ask 5 Liter Eater. I hear he has first hand experience.
Old 04-18-2013, 02:52 PM   #18
Milan
got boost?
Milan's Avatar
Unless the heads were milled to some crazy amount that we didn't notice, the compression is lower than a stock LS1.
Some more backstory: We just put this car back together after it destroyed a lifter last "season". We replaced the lifters, cam, and hit all the typical stuff while we were in there (water pump, head gaskets, etc. etc.)
To be honest we were never quite sure of the condition of the engine, I guess now we know. We did notice a very slight amount of coolant in the oil the other day when we were changing it (after bolting the heads back on from the lifter fiasco). Not sure if that independent of this or not.
Old 04-18-2013, 03:03 PM   #19
bradenW
CF Senior Member
bradenW's Avatar
Pull the heads and everything inside will tell you the story. Sucks! It made a whole lot of cylinder pressure real fast at low rpms and it found it's way out. Just hope you didn't torch the block or heads beyond repair.
bradenW is offline   Reply With Quote
Old 04-18-2013, 03:11 PM   #20
Milan
got boost?
Milan's Avatar
Yes I think we will be pulling the plugs, draining the oil and see whats going on with that, then pulling the heads....Fuuu
I'm calling it the curse of a/c man. I was just telling Brent (Y2K) yesterday that A/C man didn't start breaking **** until he went to the Ysi and that I hope we didn't go down the same path as him lol
Reload this Page Ysi + 2.75" pulley = lifting heads???
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
coolant leak aldidude C5 General 4 01-04-2014 04:06 AM
Z06 Coolant TheDingo C6 Z06 Discussion 10 09-11-2013 12:12 AM
coolant spraying out of tank on accelaration? bayarea C5 Tech 4 04-07-2013 11:16 AM
Coolant Leak JAKE-SON C4 Tech/Performance 43 11-16-2012 10:54 AM
Need a used car warranty TPFKATK Off Topic 10 07-13-2012 10:37 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
