Write-Up: Monster 2 Catch Can for Boosted Centri! (Pics)
Its a Bulkhead fitting so there is a "Large" nut on the inside, this is the nut you will tighten - I also put a little locktite to keep it secure - You do not need to needlessly crank down hard on it and overtighten it, just enough to make a good seal, which is what will happen with the 3 layer silicone coupler -
The outside Nut is part pf the Bulkhead itself -
Thanks,Matt
You will be able to securely put a nut on the backside or inside with of the coupler and add Loctite to the threads too -
You can get Nylon barbed fitting at Home Depot - in various sizes too -
Thanks,Matt
That way you pull from the natural vacuum of the motor on the TB while driving, cracking the one-way check valve open - Leaving the Blower one closed and allowing the fresh air to be pulled across the motor -
Once you go into Boost the TB one-way check valve closes and the check valve that goes to the Blower cracks open allowing the fresh air to be pulled across the motor -
Once you get out of Boost it closes and the other opens - Super simple!
Thanks,Matt
